Create topics and master Markdown formatting
Edit and write topics
Discourse uses Markdown as markup language. If you are familiar with GitHub, you’re good to go. If not, please follow this guide.
While you type something into the editor, you’ll recognize many things:
  • live preview as you type on the right side
  • if someone else is replying, a short notice on top of the editor
  • you can navigate to a different page, and still reply to the “old” topic
  • sessions are stored, which means that a draft text can be started on your Macbook and posted on your Ipad later.
You can use emojis to express your feelings. Start typing a colon : and pick one from the popup editor.
Formatting Tips
Quotes
If you need to quote a text, select it with the mouse and click the appearing "Quote button to insert it into your reply.
Code Blocks
Use three backticks for multi-line code blocks, configuration snippets, log outputs, long texts, etc. - everything you know from Wordpress’s <pre> tags or Confluence noformat or code blocks.
2018-02-01 all is good.
2018-02-02 uh, oh.
2018-02-03 kaboom.
Headings
# Heading 1
Heading 1
URLs
[url text](https://icinga.com)
becomes:
url text
Relative URLs to static pages
You can use Markdown styled URLs with relative urls, e.g. /faq
as outlined in the [FAQ](/faq)
becomes:
as outlined in the FAQ
Lists
* Major Task 1
  * Task 1
  • Major Task 1
    • Task 1
Tables
  Value | Host State | Service State
  0     | Up         | OK
  1     | Up         | Warning
  2     | Down       | Critical
  3     | Down       | Unknown
renders as
Value Host State Service State
0 Up OK
1 Up Warning
2 Down Critical
3 Down Unknown
Mentions
If you want to mention another user, just type @ and select a possible name. Once your reply is saved, this user gets notified.
Images
Images, screenshots and other graphics really help to understand a problem, or illustrate a procedure. This can be for example an exported Gliffy image, or just a printed screen.
You can add a new image with the upload icon. Either from your local disk, or from a web URL.
If you need to move the image around, just copy the entire ![31|385x233](upload://aklt7kcoGnKdMMXgCd3cxnch087.png) block to its desired location.
The embedded URL allows you to scale the image too. Discourse also downloads web images to cache them for faster access, or in case of broken images in the future.
Details
If you have a bulk of information that you want to hide behind a collapible, you can use details.
Details
[details="Details"]
This text will be hidden
[/details]
This is especially useful if you have a long chunk of config or code you want to share but not clutter up the entire topic with it.
How can i add Windows servers critical services monitoring for Icinga2?
How to add custom graphite module template
Error when deploying Apply Rule for Notifications
Modify contents of Icinga2 Alert Emails
Icinga2 notifications not sended
Windows - Disk check Unknown
Monitoring Windows Memory
How to add a satellite to an icinga master with an existing client?
Icinga client connection running in loop
Icinga2 not starting on monitored machines
Icingaweb2 and LDAPS?
Newbie: Simple Email notification for like FTP down?
Notifications
Can't get past Icingaweb2 setup on new installation
Check POST variable with check_http
Check_mysql_health as template Service, apply Service where mysql, but i want to change the treshold on the object Host
Problem with umlauts in contacts
Execute a notificationCommand with multiple users
How to sync endpoints and zones in master-satellite-client setup to satellite?
/usr/lib64/python2.7/socket.py Permission Denied
Can't start Director Background Daemon
Service checks / remote monitoring of servers from icinga clients
Check command 'systemd_service' does not exist
How can i access my icinga web after my machine ip change
HTTP WARNING - maximum redirection depth 15 exceeded - http://example.com:80/fs4webedit/s=o0Zb/
Use check_load to monitor CPU usage
How to add custom plugin and display it in IcingaWeb2?
Error During icinga2agent installation
How to call a webhook when snmp_storage triggers a warning
Icinga 2 can't connect to the Director
Windows 7 Monitoring
X509 module can't be enabled after centos upgrade
Issues getting started with Icinga2
Process information: icinga is currently not rup and running
Downtime Problem
Check_disk_smb
No services found matching the filter. | No services found matching the filter. Icingaweb
Mail notifications icinga2
Missing "graphite.url" in "/etc/icingaweb2/modules/graphite/config.ini"
Dns name for address in hosts.conf
Condition Service Check in Cluster
Prevent email notifications during downtime
Dynamic boolean value reversed?
Dependencies Host-Host
About category „Howto“ and writing guides
Logrotate on icingaweb2.log
New satellite is not working
Error in apply services after upgrade to v2.11
Problem monitoring
It seems that Icinga DB is not running. Make sure Icinga DB is running and writing into the database
Apply rule 'syno-load' 'Service' does not match anywhere!
Setting up reccuring downtime - how
Script to monitor and parse the API out
Check disk not showing the right value and right result for my server
Monitor Windows Clients ( DISK CPU and others)
Increase max_check_attemps
Icinga 2 Director - Event handler
“no Endpoint object found for identity”
Problem with my satellite
Influxdbwriter no metric on check_maxdb
REST API Icinga Directory
Satellite doesn´t check clients
Creating dependencies to limit remote notifications
Notification Icinga2 (director) -> Rocket.Chat
Agent service stuck in pending
No notifications with "times"
Create a check walktrough with director
Icinga Web shows no information
Icinga is currently not up and running
Master, Satellites and Agents
Host always in pending status
Own checks downt work since I installed new Agent on windows
Problem php
How to change ICINGA2_CA_PORT?
How to create notifications for services and hosts using icinga2web
How to clean cache info from icinga2 and icinga2 satellite servers
Execvpe( scp.exe) failed: No such file or directory
Please tell us the next host monitoring function through one server
App health check monitoring url on a specfic port
Windows plugins not working anymore?
Host with resolved structure key-value pairs does not inherit a resolved structure variable key-value pair from template?
Permission denied connecting to port 5556
No Endpoing object found for identity
Boxydash, undefined variable: host
400 Bad header
Very strange: Icinga2 does not send SMS after downtimes
Error Show All
Monitoring php-fpm processes via NRPE
Failed to remove Icinga Agent: Trying to upgrade or uninstall the agent
Help with filter on custom variables
Email Notifications are not sent
Icingaframework for Windows
PostgreSQL problem (duplicated key and connection problem reported)
ICinga+JIRA
Dashing Icinga not starting after installation
HTTP WARNING: HTTP/1.1 404 Not Found - 492 bytes in 0.029 second response time
Please help me clear Pending Deployments on my Activity log
AppImage read error
Cannot delete host from icinga2 web
Where is command_line specified now...?
Need some help with the configs for mail notification
Warning about "PING WARNING - DUPLICATES FOUND! " when use hostalive check
Extract ICINGA COMMUNITY TO ADD SWITCH
Icinga2 service failing: "config validation failed"
How to edit "service sets" Icinga2 through conf files
New icinga install on ubuntu 20.04: many PHP Deprecated errors
Notifications is not working on HA configuration
Include external Commands
Vspheredb using perfdata
icingaDB - Performance status and counters
Data extraction
School with Official Curriculum
Critical/config: Error: Include file 'itl' does not exist
Newbie question - ping4 in satellite zone overdue
Icingaweb2 connection issue
Unable to delete nodes in icinga2
Cannot increase interval notifications
Icinga PS not executed on windows client
Feedback Week Thread!
Master - Satellite - Agent
Infinite loading loop & deprecation warnings in JS files
Upgrading Icinga2 to the latest working version given my below internal modules from your experience please advise upgradable modules and links
Problem with check disk on second VPS
Icingaweb2 service check not shown in normal view only
Monitoring Windows Disks
No graphite Graphs in icingaweb
New Installation - icinag2 with ldap - unable to access /icinga2 and /icinga2web
Icinga2 Vspheredb how to get esxi host where vm runs on
Icinga2 Client could not connect to Master
Creating new command in Director with custom variable
Active host reboot check
Welcome to Discourse
urllib.error.HTTPError: HTTP Error 403: Forbidden
New in Icinga2 and with problem
