Icinga Web 2 interface changed after update
Hi everyone.
After a recent update to both of my icinga2 master servers, the web interface for one of them (Master1) has completely changed. When I log into Master1, I see all the same data I would see on Master2’s web interface, but the formatting is wildly different. For the sake of not exposing any network info, I’m posting a screenshot of the login page only.
How do I resolve this issue?
Both servers are running the same Icinga Web 2 version: 2.9.5
Both servers running CentOS 7, kernel version 3.10.0
Master1’s PHP version: 7.2.34
Master2’s PHP version: 5.4.16
Browsers: Attempted to view Master1’s web interface from Firefox, Chrome, and Edge. Same result on all three.
Please have a look here.
Thanks for the reply. I don’t have the businessprocess module running and my vsphere module appears to be updated already. I’m not sure what else to try at this point.
Also, when I run
icingacli module list installed --verbose
I receive the following output.
MODULE VERSION STATE DIRECTORY
director master enabled /usr/share/icingaweb2/modules/director
doc 2.9.5 enabled /usr/share/icingaweb2/modules/doc
grafana 1.2.1 disabled /usr/share/icingaweb2/modules/grafana
incubator v0.1.1 enabled /usr/share/icingaweb2/modules/incubator
ipl v0.1.1 enabled /usr/share/icingaweb2/modules/ipl
migrate 2.9.5 disabled /usr/share/icingaweb2/modules/migrate
monitoring 2.9.5 enabled /usr/share/icingaweb2/modules/monitoring
reactbundle v0.4.1 enabled /usr/share/icingaweb2/modules/reactbundle
reporting 0.0.0 enabled /usr/share/icingaweb2/modules/reporting
setup 2.9.5 disabled /usr/share/icingaweb2/modules/setup
translation 2.9.5 disabled /usr/share/icingaweb2/modules/translation
vspheredb 1.0.3 enabled /usr/share/icingaweb2/modules/vspheredb
https://icinga.com/docs/icinga-web-2/latest/doc/02-Installation/
ipl is way to old please remove it.
check if php-icinga is installed.
after that: disable everything except monitoring and try again.
continue enabling one module after another and logout clear browser cache and login again
reactbundle is deprecated → i think you wont need that anymore
reporting has a strange verison number please disable that too
I ended up rolling this server back to a previous snapshot (before the update that messed up my web interface). I proceeded to only update security packages and icinga2, as opposed to ALL available packages (this server hasn’t been updated since 2019). The web interface is fine now, but when I try to view the modules I have installed, I receive this message:
PHP Fatal error: Cannot declare class dipl\Loader\CompatLoader, because the name is already in use in /usr/share/icingaweb2/modules/director_old/library/vendor/ipl/Loader/CompatLoader.php on line 7
How do I completely remove ipl and reactbundle? Is this just a matter of removing their directories/files?
That’s not the v1.0.4. v1.0.3 is not compatible with Icinga Web 2 v2.9.x.
Yes. But having them still installed does not hurt. They’re still required by some parts like older Director versions.
That error is due to the director being installed multiple times.
Update!
In addition to the security and icinga2 updates, I updated php-Icinga. Immediately after, the web interface was displaying improperly again. I rolled php-Icinga back to the previous installation and the web interface is fine once again. I have no idea why this is the case. Master2 (which I’ve had no issues with) is running a more recent version of php-Icinga with no problems of any sort.
I’ve also noticed that since performing these updates, Master1’s website takes ridiculously long to load each page. I updated httpd, but still have the same issue.
And lastly, my ido2db service has failed on Master1.
● ido2db.service - LSB: Icinga IDO2DB Initscript
Loaded: loaded (/etc/rc.d/init.d/ido2db; bad; vendor preset: disabled)
Active: failed (Result: exit-code) since Thu 2022-01-13 17:39:08 HST; 2 weeks 5 days ago
Docs: man:systemd-sysv-generator(8)
Sorry if this is too much information for one post. I’ve taken over this icinga implementation a week ago and want to make sure I leave no stone unturned.
You may also have a theme active which causes problems.
This is a part from Icinga 1.x if I’m not mistaken. That was EOL long ago.
Good to know. Thank you!
