Web interface and Load Balancer
I have a HA (2 master) node icinga2 setup with icingaweb2 installed on both masters.
I have put the web interface behind a Load balancer (haproxy). but when logging in, it causes a redirect loop and errors out “too many redirects”
Is the web interface incompatible with Load balancing? is there a configuration needed in the load balancer (some http header?)
Icingaweb2 is running in Apache on each of the hosts
Haproxy
backend nms_web_back
    description nms/icinga2 web interface
    mode http
    option httpchk OPTIONS * HTTP/1.1
    http-check send hdr Host nms.internal
    http-check expect ! rstatus ^5 # only 5xx is bad
    balance roundrobin
    server nms01 host1.internal:443 check ssl verify required ca-file ca-certificates.crt fall 2 rise 2 inter 2000
    server nms02 host2.internal:443 check ssl verify required ca-file ca-certificates.crt fall 2 rise 2 inter 2000
  • Icinga Web 2 version
    2.8.2
  • Used modules and their versions (System - About)
setup	2.8.2
grafana	1.4.2
monitoring	2.8.2
  • Web browser used
    Chrome 91
  • Icinga 2 version used (icinga2 --version)
    r2.12.4-1
  • PHP version used (php --version)
    php 7.4
  • Server operating system and version
 Platform: Ubuntu
  Platform version: 20.04.2 LTS (Focal Fossa)
Still trying to debug this.
Adding a image of the browser network tab, which shows the repeated redirect between the dashboard and login.
Also, looked through the apache access logs on the 2 hosts themselves.
host1
nms.internal:443 xx.xx.xx.xx - - [09/Jul/2021:10:11:41 -0400] "GET /authentication/login?redirect=/dashboard?renderLayout&renderLayout HTTP/1.1" 200 448 "https://nms.internal/dashboard" "Mozilla/5.0 (Windows NT 10.0;Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.124 Safari/537.36
host 2
nms.internal:443 xx.xx.xx.xx - - [09/Jul/2021:10:11:41 -0400] "GET /dashboard?renderLayout HTTP/1.1" 403 413 "https://nms.internal/authentication/login?redirect=/dashboard?renderLayout" "Mozilla/5.0 (Windows NT 10.0;Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.124 Safari/537.36"
So the first request to login goes to host1, and then subsequent request for load the dashboard goes to host2 which i guess fails the authentication and redirects to login again (back on host1), repeat ad infinitum
It appears based on all my debugging and googling that icingaweb2 uses cookie based session storage to maintain authentication state (logged in). Based on that it seems that it is incompatible with Load balancing without having some kind of LB persistence enabled.
Can someone confirm that this is the case? that you need to enable Load balancer stickiness/persistence so that icingaweb2 can be load balanced?
Implemented cookie stickiness in Haproxy and it worked.
backend somename
    mode http
    cookie Icingaweb2 prefix nocache
    balance roundrobin
    server name1 hostname check cookie name1 fall 2 rise 2 inter 2000
    server name2 hostname check cookie name2 fall 2 rise 2 inter 2000
@jason.agility Which master web interface did you use? and what conf did u set in haproxy to load balance between the 2 master’s?
Hello Sameer,
I do not know what you mean by “Which master web interface did you use”. The config I used for haproxy to LB the 2 masters is available in the reply to the thread marked “solution”, but I will repeat it here:
backend somename
    mode http
    balance roundrobin
I did load balance setup with my proxy ip 192.168.1.3 …when i run this ip address it shows alternate time the content of index.html from both master(basically the default apache webpage with slight difference in both) but i need to get the icinga web interface content when i run 192.168.1.3…
It sounds like you have a problem with your apache configuration not the haproxy Load balancer.
verify your apache configuration by visiting each server directly and ensuring that the icinga interface loads.
this might have some tips:
https://icinga.com/docs/icinga-web/latest/doc/20-Advanced-Topics/
I haven’t done any work with apache configuration as all the machines are new as i am testing currently. So how do we point to get the icinga web interface instead of regular apache webpage? Do we need to do make any changes for that?
i strongly recommend you following icinga2 web installation guide:
https://icinga.com/docs/icinga-web/latest/doc/02-Installation/
and make sure you have a working icinga2 install before you start trying to deal with haproxy and multinode load balancing of the icinga2 web gui
@jason.agility
Did you add both these or just the below one? as when i run haproxy/icingaweb2 on chrome it’s changing with so many redirects but doesn’t load…
mode http
balance roundrobin
backend somename
    mode http
    balance roundrobin
I am now able to login to web interface with haproxy ip…How can i confirm if the HA has achieved with icinga? I shutdown master 1 and still see master 2 running…Any test to prove?
you should only have 1 backend for nms web interface not 2.
you suggestion on how to test HA seems like a reasonable one.
you can also check the page at “/health#!/monitoring/health/info” for the following info: “Active Icinga Web 2 Endpoint”, which will tell you which of the two icinga web hosts is currently serving the web interface. then if you take one out of load balancing, and refresh the page the value should change.
@jason.agility Thanks once again…Yeah i tried shutting down between servers and i could see changes in endpoints…This is the setup for local database on each master …How does this work if i want to use a dedicated database server instead of 2 local database? what i know is update the ido-mysql.conf with host as ip of database server and enable ha to true…is this all i have to do or any more steps ?
Another thing i noticed is when the endpoint is pointed to secondary master when primary master goes down…How can i bring the endpoint back to primary master as this would be the config master so it needs to active as soon as possible
regarding:
the active icinga web2 endpoint is not the same thing as the “active endpoint”, if you have you HA correctly configured the “active endpoint” should always go back to the master, but the “active icinga web2 endpoint”, may stay on the secondary (you have it round robin load balancer so you would get any of the two service the web interface)
as for the Database setup, check the documentation it is quite clear on the various possible setups (single db versus dual local db).
https://icinga.com/docs/icinga-2/latest/doc/06-distributed-monitoring/
https://icinga.com/docs/icinga-2/latest/doc/06-distributed-monitoring/#scenarios
@jason.agility
can you please share some info on this please
also i couldn’t get any info about setting up dedicated database server except for adding the ip in ido-mysql.conf…Could you also please help with this
See the following post about how the primary node is chosen.
also i couldn’t get any info about setting up dedicated database server except for adding the ip in ido->mysql.conf…Could you also please help with this
you have read through the documentation? because it does discuss this, if you have 2 databases, you setup will be more complicated, because you need to synchronize the databases. (HA dual master with local database or Implementing HA Master-Master setup - #4 by log1c)
