Hello everyone,
I am trying to use perfdata for check where I need to be alarmed
My service declaration :
apply Service "icingacli-vspheredb-datastore" {
import "service-10m
display_name = "Check datastore TEST
check_command = "icingacli-vspheredb
vars.vspheredb_check_mode = "datastore
vars.vspheredb_object_name = "Datastore-TEST
vars.vspheredb_perfdata = true
vars.notifications = [ ]
assign where "vmware_vcenter" in host.groups
Check command used :
object CheckCommand "icingacli-vspheredb" {
import "plugin-check-command"
command = [ "/usr/bin/icingacli", "vspheredb", "check" ]
timeout = 1m
arguments += {
"(no key)" = {
order = 1
required = true
skip_key = true
value = "$vspheredb_check_mode$"
"--name" = {
order = 2
required = false
value = "$vspheredb_object_name$"
"--perfdata" = {
order = 3
required = false
set_if = "$vspheredb_perfdata$"
When I go to influx: no perfdata
time acknowledgement current_attempt downtime_depth execution_time hostname latency max_check_attempts reachable service state state_type
1645082459000000000 0 1 0 0.054609 xxx.xxx.net 0.000293 3 true icingacli-vspheredb-datastore 0 1
When I try the command directly: no perfdata
icingacli vspheredb check datastore --name "Datastore-TEST" --perfdata
Has anyone ever been able to use perfdata?
