Troubleshooting, Debugging, Development & Technical Concepts
Troubleshooting
Please check the FAQ and the official documentation for troubleshooting hints.
Debugging & Development
The Icinga documentation provides all insights and requirements for contributing your own patches, and to debug Icinga in case of problems.
Please follow the development chapter in the docs. It covers the following interesting topics:
  • Troubleshoot Icinga with a debugger
  • Send coredumps to developers
  • Learn how Icinga is built
  • Discover the code concepts
  • Create your development environment on Linux, Windows and macOS
  • Build packages
Technical Concepts
Architecture and design concepts are documented in this chapter. This helps with analysis on specific problems e.g. check scheduling or HA enabled clusters.
