Looks like an issue similar to this came up in another post recently:
TLDR; I don’t think there is a way to do it without 2 rules… Naemon had the concept of “escalations” after a problem was unhandled for too long, but I don’t think it would achieve the result you are looking for here, and even so, I’m not entirely sure it’s implemented in Icinga.
If you’re concerned about receiving 2 recovery emails, if you setup your rules just right, you will only receive 1 (for whichever rule is in effect).
