Notification interval different values
Hello
I would like to change notification interval
I would like that:
  • normal workdays, notification interval = 14400 (4 hours)
  • weekend, notification interval = 0 (only one time the notification happens)
I tried to create two timeperiods “workday” and “weekend” different notification template with the different intervals, but when I import two notification templates on a single notification, it doesn’t mix both interval, but only one.
How could I solve my issue?
Thanks a lot
mario
icinga2 - The Icinga 2 network monitoring daemon (version: r2.13.1-1)
Icinga Web 2 Version
2.9.3
Git commit
c757a17530c326c7d6daebd6171486cb8167a8a1
PHP Version
7.2.24-0ubuntu0.18.04.8
Git commit date
2021-08-10
Modules:
businessprocess 2.3.1
director master
fileshipper 1.1.0
monitoring 2.9.3
Im also fairly new to icinga, but cant you just create two notifications?
They wont interfere, because they have separate timeslots.
I have 32 notifications, so I wouldn’t like duplicate all, only to put different interval
Just glancing, I think the only way to accomplish this is to have 2 notifications, using 2 time periods, and 2 different notification intervals.
Time Period 1:
weekdays only
Time Period 2:
weekends only
Notify Rule 1:
weekdays, notification interval 4 hours
Notify Rule 2:
weekends, notification interval disabled
Hello.
I created two timeperiod as you explained me.
I created two Notify Templates
When I put the two templates into notification apply rule, it doesn’t work.
It doesn’t apply both rules but it uses only one imports:
apply Notification "Notify Me About Hosts-ISS" to Host {
    import "Generic Host Alarm By Email Workday"
    import "Generic Host Alarm By Email Weekend"
    assign where host.vars.notification_type == "Mail" && "ISS" in host.vars.notification_recipient
    user_groups = [ "ISS" ]
How could I solve the issue?
Mario
Honestly, I didn’t think about multiple imports (or know how it works off hand, coffee might fix that).
Which import is it using? How can you tell it’s only using one (ie, it’s not the weekend yet, so the weekend rule shouldn’t be in effect).
You could use the templates to create 2 different Notification apply rules and see if that helps, that was my intended solution, but I like the idea of multiple imports better if it works :slight_smile:
With multiple import it mixed timeperiod and notification’s interval, so it doesn’t work right.
Can you show the templates and the evidence showing that they’re mixed?
Ah, I think the multiple imports won’t work for intervals and time periods, since only one value can be defined for those.
