Process information: icinga is currently not rup and running
Hi
Could you please help me with below issue?
I have set up icinga and icingaweb2 successfully without any issues. However, after launcing icingaweb UI, I could see the process information as “icinga is currently not up and running”. It is not showing any hosts
I could see above message under system->monitoring health->process information.
Tried to attached screenshot, it seems there is an issued in uploading atachments
Kindly help me with above issue
Environment: Linux Redhat
database : postgresql
Thanks&Regards
Srinivas
You might have a look at this maybe your run into the same issue.
Hi Sommer
Thanks for the prompt response
As mention in the link provided, i ran the query
select status_update_time from icinga_programstatus;
Result : (0 rows)
Below is the query and result
icinga=> select status_update_time from icinga_programstatus;
status_update_time
(0 rows)
Could you please advise what should be my next step?
In my case it is postgresql
Thanks&regards
Srinivas
You just need to reload icinga2. If the table is still empty, then your IDO is not working properly or IDO is not enabled. The latter you can check with:
icinga2 feature list
Hi Sommer
Below are the features enabled.
api.conf, checker.conf, command.conf, ido-pgsql.conf, logfile, mainlog.conf, notiifcation.conf, perfdata.conf
And ido-pgsql.conf is as below
  • The IdoPgsqlConnection type implements PostgreSQL support
  • for DB IDO.
object IdoPgsqlConnection “ido-pgsql” {
user = “icinga”
password = “xxxxxx”
host = “localhost”
database = “icinga”
Also, I forgot to mention, this is my fresh installation of icinga
Thanks&Regards
Srinivas
Have you already tried to login with that credentials to the database? Any hints in the icinga logs?
Hi
Below is the icinga2.log file message
(IdoPgsqlConnection, ido-pgsql) items: 1, rate: 2/s (120/min 638/5min 1304/15min);
[2020-01-13 11:58:03 +0100] critical/IdoPgsqlConnection: Connection to database ‘icinga’ with user ‘icinga’ on ‘localhost:5432’ failed: "could not connect to server: Connection refused
Is the server running on host “localhost” (127.0.0.1) and accepting
TCP/IP connections on port 5432?
But in resources.ini file, I have changed the port 5432 to different port
I could login to database. Below is the sample query i tried connecting to pgsql
status_update_time
(0 rows)
Thanks&Regards
Srinivas
Ah, then you need the port definition in your ido-pgsql.conf.
Hi
Thank you
I updated ido_pgsql.conf file adding port and restarted icinga and apache services. Still, no hosts is dispalyed in web console. same message “icinga is currently not up and running”
  • for DB IDO.
user = “icinga”
password = “xxxxxx”
host = “localhost”
port = “xxxxx”
database = “icinga”
Thanks&Regards
Srinivas
Anything in the logs?
Hi
Below is the log content
[2020-01-13 14:18:25 +0100] critical/IdoPgsqlConnection: Connection to database ‘icinga’ with user ‘icinga’ on ‘localhost:5432’ failed: "could not connect to server: Connection refused
Context:
(0) Reconnecting to PostgreSQL IDO database ‘ido-pgsql’
[2020-01-13 14:18:25 +0100] warning/IdoPgsqlConnection: Exception during database operation: Verify that your database is operational!
[2020-01-13 14:18:27 +0100] warning/PluginCheckTask: Check command for object ‘localhost!ping4’ (PID: 72983, arguments: ‘/icinga2/icinga/usr/lib/nagios/plugins/check_ping’ ‘-4’ ‘-H’ ‘127.0.0.1’ ‘-c’ ‘200,15%’ ‘-w’ ‘100,5%’) terminated with exit code 128, output: execvpe(/icinga2/icinga/usr/lib/nagios/plugins/check_ping) failed: No such file or directory
I just replaced hostname by “localhost” in the above content otherwise everything is as it is.
Thanks&Regards
Srinivas
IDO tries to connect on the default port and not at your customized port. Could you share
icinga2 object list -n ido-pgsql
The path is completely wrong, I’d assume you change ConfigDir constant to wrong value.
Hi
The issue is resolved after making changes as you suggested .
changing the port to customized port
also changed the username and password to the actual values I gave during database setup.
Now, console is showing the host and the issues
One issue is resolved
Now, I could see on icinga web the below issue under services.
I just verified the constans.conf file and could see the below. There paths were defined by default.
const PluginContribDir = “/icinga2/icinga/usr/lib/nagios/plugins”
const ManubulonPluginDir = "/icinga2/icinga/usr/lib/nagios/plugins
Do I need to change anything here
Thanks&Regards
Srinivas
Adding to above
on console below is the issue is displayed
execvpe(/icinga2/icinga/usr/lib/nagios/plugins/check_disk) failed: No such file or directory
the default constants.conf looks like:
 * This file defines global constants which can be used in
 * the other configuration files.
/* The directory which contains the plugins from the Monitoring Plugins project. */
const PluginDir = "/usr/lib/nagios/plugins"
/* The directory which contains the Manubulon plugins.
 * Check the documentation, chapter "SNMP Manubulon Plugin Check Commands", for details.
const ManubulonPluginDir = "/usr/lib/nagios/plugins"
/* The directory which you use to store additional plugins which ITL provides user contributed command definitions for.
 * Check the documentation, chapter "Plugins Contribution", for details.
const PluginContribDir = "/usr/lib/nagios/plugins"
Hi
Actually, we have used custom paths (as per customer requirement) so the path is different.
I just verified the plugins
under this path I could see only one file “check_nscp_api”
Is this correct?
As per above issue, icinga is looking for check_disk under plungins which is not avaialble.
Please suggest me if I need to make any changes
Thanks&Regards
Srinivas
You need to make sure that the path to the plugins correspond to the constants. If there are some plugins missing in that directory, you need to copy/install them.
Hi
Thank you so much for your support.
I shall install the missing pulgins and ensure the correct path.
Thanks&Regards
Srinivas
Hi
I installed missing nagios plugins and copy them in the correct path.
Now that issue is gone.
Thanks for the support
Thanks&Regards
Srinivas
Hi @srinivas
two small requests for future topics/posts:
In future please use the markdown options to format your posts, especially if they contain code/config/log snippets. This way you make it easier for people trying the help reading your posts :slight_smile:
Here you can find a HowTo for this:
Also please pick a solution to topic that have been successfully solved.
This way you can “reward” the solution author and visibly mark the topic as solved :slight_smile:
