hi i’m trying to use icinga2 for my computer but when i go to the webpage i got this message:
Fatal error: Uncaught ErrorException: session_name(): Cannot change session name when session is active in /usr/share/php/Icinga/Web/Session/PhpSession.php:97
Stack trace:
#0 [internal function]: Icinga\Application\ApplicationBootstrap->Icinga\Application\{closure}(2, 'session_name():...', '/usr/share/php/...', 97, Array)
#1 /usr/share/php/Icinga/Web/Session/PhpSession.php(97): session_name('Icingaweb2')
#2 /usr/share/php/Icinga/Web/Session/PhpSession.php(152): Icinga\Web\Session\PhpSession->open()
#3 /usr/share/php/Icinga/Web/Controller/ActionController.php(544): Icinga\Web\Session\PhpSession->write()
#4 /usr/share/php/Icinga/Web/Controller/ActionController.php(489): Icinga\Web\Controller\ActionController->shutdownSession()
#5 /usr/share/icingaweb2/library/vendor/Zend/Controller/Action.php(512): Icinga\Web\Controller\ActionController->postDispatch()
#6 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(76): Zend_Controller_Action->dispatch('errorAction')
#7 /usr/share/icingaweb2/library/vendor/Zend/Controller/Front.php( in /usr/share/icingaweb2/library/vendor/Zend/Controller/Plugin/Broker.php on line 332
pls can someone explain me what is the problem or even if you have a solution.
