Hi all,
I’m new to Icinga but through the manual I configured with success Icingaweb.
Now I want to add my machines to the monitoring but I have the following problem:
I tested 1 Windows VM, it appears on the webpage but I don’t see the monitoring of the resources.
Searching in the community I found how to add parameters but instead of showing me resources of the VM, it shows me the local resources (the ones of Icinga server).
So I tried add more details trying to solve this, but the problem persist.
For Example here is the configuration in service.conf for hard disk:
apply Service for (disk => config in host.vars.local_disks) {
import “generic-service”
check_command = “disk-windows”
assign where host.vars.agent_endpoint
vars.disk_win_show_used = “true”
vars += config
assign where host.vars.os == “Windows”
vars.disk_wfree = “10%”
vars.disk_cfree = “5%”
The result on Icingaweb is: execvpe(/usr/lib64/nagios/plugins/check_disk.exe) failed: No such file or directory
Moreover I want to see also the RAM & CPU usage.
Can anyone help me?
Thanks in advance
