I’m getting this error on the
connect to address x.x.x.x port 5666: Permission denied
connect to host correct.fqdn.my.domain port 5666: Permission denied
The check is based on NRPE and works well from the command line.
/usr/lib64/nagios/plugins/check_nrpe -H correct.fqdn.my.domain -c check_base_disk
config:
object Service “disk” {
import “generic-service”
host_name = “correct.fqdn.my.domain”
check_command = “nrpe”
vars.nrpe_command = “check_base_disk”
vars.nrpe_arguments = [ “20%”, “10%”, “/” ]
Can someone be kind enough to point out my error?
