we are currently seeing a large increase in memory usage after we enabled some passive checks. We have a few other things going on in this system, so working out which of the new things are causing the problem is something we are going to have to work through. At a basic level the current problem is:
icinga2 starts and then OOMs out after a few days at about 8G of RAM used.
After about 30mins of run time:
smem -ak |grep icinga2
3284954 root grep icinga2 0 348.0K 437.0K 2.2M
3271908 nagios /usr/lib/x86_64-linux-gnu/icinga2/sbin/icinga2 --no-stack-rlimit daemon --close-stdi 184.0K 308.0K 1.7M 6.0M
3271809 nagios /usr/lib/x86_64-linux-gnu/icinga2/sbin/icinga2 --no-stack-rlimit daemon --close-stdi 0 1.7M 6.1M 17.4M
3271867 nagios /usr/lib/x86_64-linux-gnu/icinga2/sbin/icinga2 --no-stack-rlimit daemon --close-stdi 0 1.4G 1.4G 1.4G
This icinga install is weird in a few ways which I will get to, but first the basics:
Version:
icinga2 --version:
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.0-1)
Copyright (c) 2012-2023 Icinga GmbH (https://icinga.com/)
License GPLv2+: GNU GPL version 2 or later https://gnu.org/licenses/gpl2.html
System information:
Platform: Debian GNU/Linux
Platform version: 11 (bullseye)
Kernel: Linux
Kernel version: 5.10.0-23-amd64
Architecture: x86_64
Build information:
Compiler: GNU 10.2.1
OpenSSL version: OpenSSL 1.1.1n 15 Mar 2022
icinga2 feature list
Disabled features: command compatlog debuglog elasticsearch gelf graphite icingadb influxdb influxdb2 journald livestatus opentsdb perfdata statusdata syslog
Enabled features: api checker ido-mysql mainlog notification
(Yes I disabled influxdbwriter in case it was that)
Some idea on scale:
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 6 NotificationCommands.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 378 Notifications.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 1 IcingaApplication.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 1932 Hosts.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 1373 HostGroups.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 1 Downtime.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 63 Comments.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 1 IdoMysqlConnection.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 1 FileLogger.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 40 Zones.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 1 CheckerComponent.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 38 Endpoints.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 11 ApiUsers.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 1 NotificationComponent.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 1 ApiListener.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 327 CheckCommands.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 5 TimePeriods.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 3 UserGroups.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 111 Users.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 6565 Services.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 704 ServiceGroups.
[2023-07-30 23:26:28 +0000] information/ConfigItem: Instantiated 1 ScheduledDowntime.
icinga2 object list|grep check_command|wc -l
8564
icinga2 object list|grep check_command|grep passive|wc -l
812
The weird stuff is that this instance is also hit very hard on the API call front. While this load has been present for a long time, the passive checks is new, and other API calls are newish (arriving for the same project). So its hard to tell exactly what config change we made triggered this enormous memory usage. Upgrading to 2.14 didn’t help the situation unfortunately.
Any ideas on how to debug this further? Is there some magic way we can inspect the icinga2 process to figure out which bit is triggering the memory usage?
We are busy building a lab replica of the environment so we can further understand the problem and adjust various parameters to find the leak.
here is the OOM error:
[Tue Jul 25 20:42:49 2023] haproxy invoked oom-killer: gfp_mask=0x100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
[Tue Jul 25 20:42:49 2023] CPU: 7 PID: 1038 Comm: haproxy Not tainted 5.10.0-23-amd64 #1 Debian 5.10.179-1
[Tue Jul 25 20:42:49 2023] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 11/12/2020
[Tue Jul 25 20:42:49 2023] Call Trace:
[Tue Jul 25 20:42:49 2023] dump_stack+0x6b/0x83
[Tue Jul 25 20:42:49 2023] dump_header+0x4a/0x1f4
[Tue Jul 25 20:42:49 2023] oom_kill_process.cold+0xb/0x10
[Tue Jul 25 20:42:49 2023] out_of_memory+0x1bd/0x4e0
[Tue Jul 25 20:42:49 2023] __alloc_pages_slowpath.constprop.0+0xbcc/0xc90
[Tue Jul 25 20:42:49 2023] __alloc_pages_nodemask+0x2de/0x310
[Tue Jul 25 20:42:49 2023] pagecache_get_page+0x175/0x390
[Tue Jul 25 20:42:49 2023] filemap_fault+0x6a2/0x900
[Tue Jul 25 20:42:49 2023] ? xas_load+0x5/0x80
[Tue Jul 25 20:42:49 2023] ext4_filemap_fault+0x2d/0x50 [ext4]
[Tue Jul 25 20:42:49 2023] __do_fault+0x34/0x170
[Tue Jul 25 20:42:49 2023] handle_mm_fault+0x124f/0x1c00
[Tue Jul 25 20:42:49 2023] ? __hrtimer_init+0xd0/0xd0
[Tue Jul 25 20:42:49 2023] do_user_addr_fault+0x1b8/0x400
[Tue Jul 25 20:42:49 2023] ? switch_fpu_return+0x44/0xc0
[Tue Jul 25 20:42:49 2023] exc_page_fault+0x78/0x160
[Tue Jul 25 20:42:49 2023] ? asm_exc_page_fault+0x8/0x30
[Tue Jul 25 20:42:49 2023] asm_exc_page_fault+0x1e/0x30
[Tue Jul 25 20:42:49 2023] RIP: 0033:0x555bb5df91b3
[Tue Jul 25 20:42:49 2023] Code: Unable to access opcode bytes at RIP 0x555bb5df9189.
[Tue Jul 25 20:42:49 2023] RSP: 002b:00007f7193fec370 EFLAGS: 00010202
[Tue Jul 25 20:42:49 2023] RAX: 0000000000000000 RBX: 00000000000001ca RCX: 00007f71a0698d56
[Tue Jul 25 20:42:49 2023] RDX: 00000000000000c8 RSI: 00007f7140015c50 RDI: 0000000000000000
[Tue Jul 25 20:42:49 2023] RBP: 00000000000001ca R08: 0000000000000000 R09: ffffffffffff7ef8
[Tue Jul 25 20:42:49 2023] R10: 00000000000001ca R11: 0000000000000000 R12: 000000008eca42f6
[Tue Jul 25 20:42:49 2023] R13: 0000000000000000 R14: ffffffffffff7e70 R15: 0000000eab17b600
[Tue Jul 25 20:42:49 2023] Mem-Info:
[Tue Jul 25 20:42:49 2023] active_anon:2282074 inactive_anon:5746309 isolated_anon:0
active_file:0 inactive_file:334 isolated_file:0
unevictable:1 dirty:0 writeback:0
slab_reclaimable:37987 slab_unreclaimable:32888
mapped:5865 shmem:5715 pagetables:23912 bounce:0
free:49420 free_pcp:248 free_cma:0
[Tue Jul 25 20:42:49 2023] Node 0 active_anon:9128296kB inactive_anon:22985236kB active_file:0kB inactive_file:1336kB unevictable:4kB isolated(anon):0kB isolated(file):0kB mapped:23460kB dirty:0kB writeback:0kB shmem:22860kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 13916160kB writeback_tmp:0kB kernel_stack:9520kB all_unreclaimable? yes
[Tue Jul 25 20:42:49 2023] Node 0 DMA free:11812kB min:32kB low:44kB high:56kB reserved_highatomic:0KB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15992kB managed:15908kB mlocked:0kB pagetables:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[Tue Jul 25 20:42:49 2023] lowmem_reserve: 0 2964 32045 32045 32045
[Tue Jul 25 20:42:49 2023] Node 0 DMA32 free:122556kB min:6248kB low:9280kB high:12312kB reserved_highatomic:0KB active_anon:526860kB inactive_anon:2377692kB active_file:292kB inactive_file:0kB unevictable:0kB writepending:0kB present:3129216kB managed:3063680kB mlocked:0kB pagetables:1736kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[Tue Jul 25 20:42:49 2023] lowmem_reserve: 0 0 29081 29081 29081
[Tue Jul 25 20:42:49 2023] Node 0 Normal free:63312kB min:61300kB low:91076kB high:120852kB reserved_highatomic:0KB active_anon:8601436kB inactive_anon:20607332kB active_file:0kB inactive_file:2356kB unevictable:4kB writepending:0kB present:30408704kB managed:29786616kB mlocked:4kB pagetables:93912kB bounce:0kB free_pcp:992kB local_pcp:0kB free_cma:0kB
[Tue Jul 25 20:42:49 2023] lowmem_reserve: 0 0 0 0 0
[Tue Jul 25 20:42:49 2023] Node 0 DMA: 14kB (U) 08kB 016kB 132kB (U) 264kB (U) 1128kB (U) 1256kB (U) 0512kB 11024kB (U) 12048kB (M) 24096kB (M) = 11812kB
[Tue Jul 25 20:42:49 2023] Node 0 DMA32: 3954kB (UME) 3348kB (UME) 94416kB (UME) 74732kB (UME) 42664kB (UME) 132128kB (UME) 72256kB (UME) 28512kB (UE) 31024kB (ME) 02048kB 04096kB = 123260kB
[Tue Jul 25 20:42:49 2023] Node 0 Normal: 20154kB (UME) 9958kB (UME) 95016kB (UME) 48232kB (ME) 16664kB (UME) 41128kB (ME) 8256kB (ME) 2512kB (UM) 01024kB 02048kB 0*4096kB = 65588kB
[Tue Jul 25 20:42:49 2023] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB
[Tue Jul 25 20:42:49 2023] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
[Tue Jul 25 20:42:49 2023] 205698 total pagecache pages
[Tue Jul 25 20:42:49 2023] 199163 pages in swap cache
[Tue Jul 25 20:42:49 2023] Swap cache stats: add 17704135, delete 17515334, find 83537704/84268080
[Tue Jul 25 20:42:49 2023] Free swap = 0kB
[Tue Jul 25 20:42:49 2023] Total swap = 10485756kB
[Tue Jul 25 20:42:49 2023] 8388478 pages RAM
[Tue Jul 25 20:42:49 2023] 0 pages HighMem/MovableOnly
[Tue Jul 25 20:42:49 2023] 171927 pages reserved
[Tue Jul 25 20:42:49 2023] 0 pages hwpoisoned
[Tue Jul 25 20:42:49 2023] Tasks state (memory values in pages):
[Tue Jul 25 20:42:49 2023] [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name
[Tue Jul 25 20:42:49 2023] [ 567] 0 567 81018 343 643072 495 -250 systemd-journal
[Tue Jul 25 20:42:49 2023] [ 591] 0 591 5535 161 69632 265 -1000 systemd-udevd
[Tue Jul 25 20:42:49 2023] [ 856] 107 856 1975 47 53248 66 0 rpcbind
[Tue Jul 25 20:42:49 2023] [ 858] 0 858 11937 111 86016 261 0 VGAuthService
[Tue Jul 25 20:42:49 2023] [ 859] 0 859 59065 633 98304 196 0 vmtoolsd
[Tue Jul 25 20:42:49 2023] [ 860] 104 860 2098 144 53248 48 -900 dbus-daemon
[Tue Jul 25 20:42:49 2023] [ 864] 0 864 567842 8880 585728 3309 0 jumpcloud-agent
[Tue Jul 25 20:42:49 2023] [ 868] 0 868 2866 193 57344 80 0 openvpn
[Tue Jul 25 20:42:49 2023] [ 874] 0 874 72716 752 94208 172 0 rsyslogd
[Tue Jul 25 20:42:49 2023] [ 881] 0 881 3497 171 65536 95 0 systemd-logind
[Tue Jul 25 20:42:49 2023] [ 885] 109 885 18649 106 61440 71 0 ntpd
[Tue Jul 25 20:42:49 2023] [ 886] 0 886 1686 37 57344 28 0 cron
[Tue Jul 25 20:42:49 2023] [ 917] 0 917 1461 0 49152 32 0 agetty
[Tue Jul 25 20:42:49 2023] [ 1004] 108 1004 2874342 1640982 16629760 310385 0 mariadbd
[Tue Jul 25 20:42:49 2023] [ 1017] 0 1017 58858 1734 204800 1495 0 apache2
[Tue Jul 25 20:42:49 2023] [ 1022] 0 1022 36879 85 172032 9535 0 haproxy
[Tue Jul 25 20:42:49 2023] [ 1027] 110 1027 378478 12861 401408 8917 0 haproxy
[Tue Jul 25 20:42:49 2023] [ 1279] 0 1279 10012 29 69632 133 0 master
[Tue Jul 25 20:42:49 2023] [ 1282] 112 1282 10124 62 77824 137 0 qmgr
[Tue Jul 25 20:42:49 2023] [ 1317] 997 1317 1170972 43123 1310720 26970 0 vector
[Tue Jul 25 20:42:49 2023] [ 1371] 997 1371 229133 76 1355776 132 0 journalctl
[Tue Jul 25 20:42:49 2023] [ 2120] 0 2120 3683 7 69632 302 0 sshd
[Tue Jul 25 20:42:49 2023] [ 2167] 1006 2167 3828 149 73728 174 0 systemd
[Tue Jul 25 20:42:49 2023] [ 2169] 1006 2169 41736 106 98304 543 0 (sd-pam)
[Tue Jul 25 20:42:49 2023] [ 2219] 1006 2219 3683 44 69632 266 0 sshd
[Tue Jul 25 20:42:49 2023] [ 2224] 1006 2224 2171 38 53248 487 0 bash
[Tue Jul 25 20:42:49 2023] [ 102182] 112 102182 11027 59 77824 191 0 tlsmgr
[Tue Jul 25 20:42:49 2023] [1078586] 0 1078586 3683 43 69632 271 0 sshd
[Tue Jul 25 20:42:49 2023] [1078761] 1012 1078761 3828 268 69632 54 0 systemd
[Tue Jul 25 20:42:49 2023] [1078762] 1012 1078762 41730 82 98304 644 0 (sd-pam)
[Tue Jul 25 20:42:49 2023] [1078782] 1012 1078782 4309 608 77824 374 0 sshd
[Tue Jul 25 20:42:49 2023] [1078783] 1012 1078783 2213 1 53248 561 0 bash
[Tue Jul 25 20:42:49 2023] [ 191820] 0 191820 3683 13 65536 296 0 sshd
[Tue Jul 25 20:42:49 2023] [ 191833] 1006 191833 3683 39 65536 271 0 sshd
[Tue Jul 25 20:42:49 2023] [ 191834] 1006 191834 2042 169 53248 220 0 bash
[Tue Jul 25 20:42:49 2023] [ 248759] 0 248759 3683 7 69632 303 0 sshd
[Tue Jul 25 20:42:49 2023] [ 248765] 1006 248765 3683 30 69632 281 0 sshd
[Tue Jul 25 20:42:49 2023] [ 248766] 1006 248766 2042 117 53248 272 0 bash
[Tue Jul 25 20:42:49 2023] [ 248847] 1006 248847 3011 142 61440 35 0 ssh
[Tue Jul 25 20:42:49 2023] [1023190] 0 1023190 3683 58 65536 252 0 sshd
[Tue Jul 25 20:42:49 2023] [1023198] 1006 1023198 3683 101 65536 222 0 sshd
[Tue Jul 25 20:42:49 2023] [1023199] 1006 1023199 2042 126 57344 263 0 bash
[Tue Jul 25 20:42:49 2023] [1023235] 1006 1023235 3041 214 61440 15 0 ssh
[Tue Jul 25 20:42:49 2023] [1206558] 1006 1206558 2697 52 57344 96 0 sudo
[Tue Jul 25 20:42:49 2023] [1206559] 0 1206559 2042 389 53248 4 0 bash
[Tue Jul 25 20:42:49 2023] [1773676] 106 1773676 362499 149 233472 448 0 icinga2
[Tue Jul 25 20:42:49 2023] [2876162] 106 2876162 8647662 5970931 66658304 2258144 0 icinga2
[Tue Jul 25 20:42:49 2023] [2876203] 106 2876203 362499 209 217088 395 0 icinga2
[Tue Jul 25 20:42:49 2023] [3540786] 0 3540786 3338 171 65536 67 -1000 sshd
[Tue Jul 25 20:42:49 2023] [3542014] 33 3542014 79714 5869 282624 2408 0 apache2
[Tue Jul 25 20:42:49 2023] [3543940] 33 3543940 79297 5964 282624 2053 0 apache2
[Tue Jul 25 20:42:49 2023] [3762914] 0 3762914 3683 304 65536 9 0 sshd
[Tue Jul 25 20:42:49 2023] [3762929] 1012 3762929 3735 331 69632 89 0 sshd
[Tue Jul 25 20:42:49 2023] [3762931] 1012 3762931 2349 531 61440 51 0 bash
[Tue Jul 25 20:42:49 2023] [3780198] 1012 3780198 2697 120 57344 28 0 sudo
[Tue Jul 25 20:42:49 2023] [3780224] 0 3780224 2341 554 61440 139 0 bash
[Tue Jul 25 20:42:49 2023] [3863842] 33 3863842 78462 4600 245760 1392 0 apache2
[Tue Jul 25 20:42:49 2023] [3866825] 33 3866825 59862 4434 233472 1314 0 apache2
[Tue Jul 25 20:42:49 2023] [3866826] 33 3866826 59846 4444 233472 1316 0 apache2
[Tue Jul 25 20:42:49 2023] [3867829] 33 3867829 59844 4435 233472 1314 0 apache2
[Tue Jul 25 20:42:49 2023] [3867837] 33 3867837 59848 4441 233472 1313 0 apache2
[Tue Jul 25 20:42:49 2023] [3867838] 33 3867838 59847 4432 233472 1315 0 apache2
[Tue Jul 25 20:42:49 2023] [4049422] 33 4049422 59861 4474 233472 1271 0 apache2
[Tue Jul 25 20:42:49 2023] [4049423] 33 4049423 59858 4652 233472 1267 0 apache2
[Tue Jul 25 20:42:49 2023] [ 20419] 998 20419 27057 3181 196608 0 0 icingacli
[Tue Jul 25 20:42:49 2023] [ 44063] 112 44063 10076 162 61440 0 0 pickup
[Tue Jul 25 20:42:49 2023] [ 78164] 1036 78164 3822 299 69632 0 0 systemd
[Tue Jul 25 20:42:49 2023] [ 78165] 1036 78165 42247 628 102400 122 0 (sd-pam)
[Tue Jul 25 20:42:49 2023] [ 78187] 998 78187 51190 27210 397312 0 0 icingacli
[Tue Jul 25 20:42:49 2023] [ 78222] 106 78222 8873 4777 106496 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78223] 106 78223 8438 4297 102400 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78224] 106 78224 8566 4413 106496 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78225] 106 78225 8874 4762 110592 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78226] 106 78226 8938 4781 110592 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78227] 106 78227 8938 4780 110592 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78228] 106 78228 8938 4779 106496 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78229] 106 78229 6939 2823 90112 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78231] 106 78231 7299 3172 98304 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78233] 106 78233 7299 3158 98304 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78234] 106 78234 7398 3266 94208 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78235] 106 78235 7630 3497 98304 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78239] 106 78239 7332 3198 98304 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78241] 106 78241 7135 2947 98304 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78242] 106 78242 6762 2686 94208 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78243] 106 78243 6933 2815 90112 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78244] 106 78244 6629 2534 90112 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78245] 106 78245 6762 2677 94208 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78246] 106 78246 6861 2734 90112 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78247] 106 78247 27030 2699 200704 0 0 icingacli
[Tue Jul 25 20:42:49 2023] [ 78248] 106 78248 6762 2691 94208 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78249] 106 78249 26518 2524 196608 0 0 icingacli
[Tue Jul 25 20:42:49 2023] [ 78250] 106 78250 6939 2823 98304 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78251] 106 78251 6680 2614 86016 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78252] 106 78252 27030 2863 196608 0 0 icingacli
[Tue Jul 25 20:42:49 2023] [ 78253] 106 78253 27030 2569 208896 0 0 icingacli
[Tue Jul 25 20:42:49 2023] [ 78254] 106 78254 5280 2051 81920 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78255] 106 78255 25590 1272 188416 0 0 icingacli
[Tue Jul 25 20:42:49 2023] [ 78256] 106 78256 25435 1135 188416 0 0 icingacli
[Tue Jul 25 20:42:49 2023] [ 78257] 106 78257 5182 1949 77824 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78258] 106 78258 24130 868 176128 0 0 icingacli
[Tue Jul 25 20:42:49 2023] [ 78259] 106 78259 13042 369 94208 0 0 icingacli
[Tue Jul 25 20:42:49 2023] [ 78260] 106 78260 19770 702 143360 0 0 icingacli
[Tue Jul 25 20:42:49 2023] [ 78261] 106 78261 3622 538 65536 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78262] 106 78262 11725 154 73728 0 0 icingacli
[Tue Jul 25 20:42:49 2023] [ 78263] 106 78263 3392 349 69632 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78264] 106 78264 362499 224 208896 380 0 icinga2
[Tue Jul 25 20:42:49 2023] [ 78265] 106 78265 3161 41 61440 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78266] 106 78266 3161 41 61440 0 0 python3
[Tue Jul 25 20:42:49 2023] [ 78268] 0 78268 2253 40 49152 0 0 sshd
[Tue Jul 25 20:42:49 2023] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/icinga2.service,task=icinga2,pid=2876162,uid=106
[Tue Jul 25 20:42:49 2023] Out of memory: Killed process 2876162 (icinga2) total-vm:34590648kB, anon-rss:23883724kB, file-rss:0kB, shmem-rss:0kB, UID:106 pgtables:65096kB oom_score_adj:0
[Tue Jul 25 20:42:52 2023] oom_reaper: reaped process 2876162 (icinga2), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
