Icingaweb2 was upgraded from 2.8.5 to 2.9.0. After upgrade the UI web pages won’t properly anymore.
# ls -alF /usr/share/icingaweb2/modules
total 60
drwxr-xr-x 15 root root 4096 Jul 12 2021 ./
drwxr-xr-x 8 root root 4096 Jul 12 2021 ../
drwxr-xr-x 9 root root 4096 Nov 2 2019 businessprocess/
drwxr-xr-x 10 root root 4096 Apr 29 2022 director/
drwxr-xr-x 6 root root 4096 May 6 13:25 doc/
drwxr-xr-x 9 root root 4096 Dec 25 2019 grafana/
drwxr-sr-x 9 apache icingaweb2 4096 Aug 27 2019 graphite/
drwxr-xr-x 5 root root 4096 Oct 28 2022 incubator/
drwxr-xr-x 5 root root 4096 Mar 25 2022 ipl/
drwxr-xr-x 7 root root 4096 May 6 13:26 monitoring/
drwxr-xr-x 4 root root 4096 Mar 25 2022 reactbundle/
drwxr-xr-x 5 root root 4096 May 6 13:26 setup/
drwxr-xr-x 5 root root 4096 May 6 13:26 translation/
drwxr-xr-x 10 root root 4096 Oct 28 2022 vspheredb/
drwxr-xr-x 11 root root 4096 Nov 2 2019 x509/
# icingacli module list installed --verbose
MODULE VERSION STATE DIRECTORY
businessprocess 2.2.0 disabled /mnt/usr/share/icingaweb2/modules/businessprocess
Launching the run script /mnt/usr/share/icingaweb2/modules/director/run.php for module director failed with the following exception: Missing dependencies, please check
director 1.8.1 disabled /mnt/usr/share/icingaweb2/modules/director
doc 2.9.0 disabled /mnt/usr/share/icingaweb2/modules/doc
grafana 1.3.6 disabled /mnt/usr/share/icingaweb2/modules/grafana
graphite 1.1.0 disabled /mnt/usr/share/icingaweb2/modules/graphite
incubator 0.19.0 disabled /mnt/usr/share/icingaweb2/modules/incubator
ipl v0.5.0 disabled /mnt/usr/share/icingaweb2/modules/ipl
monitoring 2.9.0 enabled /mnt/usr/share/icingaweb2/modules/monitoring
reactbundle 0.9.0 disabled /mnt/usr/share/icingaweb2/modules/reactbundle
setup 2.9.0 disabled /mnt/usr/share/icingaweb2/modules/setup
translation 2.9.0 disabled /mnt/usr/share/icingaweb2/modules/translation
Launching the run script /mnt/usr/share/icingaweb2/modules/vspheredb/run.php for module vspheredb failed with the following exception: Missing dependencies, please check
vspheredb 1.5.0 disabled /mnt/usr/share/icingaweb2/modules/vspheredb
x509 1.0.0 disabled /mnt/usr/share/icingaweb2/modules/x509
/icingaweb2/css/icinga.css gives this error
Fatal error: Uncaught Less_Exception_Compiler: Operation on an invalid type in /usr/share/icinga-php/ipl/vendor/wikimedia/less.php/lib/Less/Tree/Operation.php:40 Stack trace: #0 /usr/share/icinga-php/ipl/vendor/wikimedia/less.php/lib/Less/Tree/Expression.php(46): Less_Tree_Operation->compile(Object(Less_Environment)) #1 /usr/share/icinga-php/ipl/vendor/wikimedia/less.php/lib/Less/Tree/Call.php(40): Less_Tree_Expression->compile(Object(Less_Environment)) #2 /usr/share/icinga-php/ipl/vendor/wikimedia/less.php/lib/Less/Tree/Expression.php(46): Less_Tree_Call->compile(Object(Less_Environment)) #3 /usr/share/icinga-php/ipl/vendor/wikimedia/less.php/lib/Less/Tree/Value.php(25): Less_Tree_Expression->compile(Object(Less_Environment)) #4 /usr/share/icinga-php/ipl/vendor/wikimedia/less.php/lib/Less/Tree/Rule.php(76): Less_Tree_Value->compile(Object(Less_Environment)) #5 /usr/share/icinga-php/ipl/vendor/wikimedia/less.php/lib/Less/Tree/Ruleset.php(95): Less_Tree_Rule->compile(Object(Less_Environment)) #6 /usr/share/icinga-php/ipl/v in /usr/share/icinga-php/ipl/vendor/wikimedia/less.php/lib/Less/Tree/Operation.php on line 40
