Hi
For some reason, the Icingaweb2 UI - CSS won’t load on the second master. It is working alright on the config master.
I restarted httpd service but that didn’t help. Any ideas?
Hi
most likely it is a module / library not updated correctly.
disable all modules and enable them one after the other, of course with their dependecies.
upgraded to 2.9.7 which resolved the issue. Thanks
