Icinga2 | Elasticsearch Writer showing error "No Handler Found"
Hi Everyone,
As per my use case, I am trying to writer my performance data from icinga2 into the Elasticsearch. For that I am using Elasticsearch writer. The configuration for whom is given below. After configuring the ES writer as defined in icinga2 documentations, link for that is given below. I am getting below ES writer error in my icinga2 logs. For testing purposes I have disabled x-pack from Elasticsearch to avoid any authentication errors/handling. But still its not working. I require some assistance to troubleshoot this error. Any help will be highly appreciated. Thanks in advance.
I am using cinga = 2.13.2, icingaweb = 2.9.5 and elasticsearch = 8.3.2.
Elasticsearch Writer Icinga2 Docs
Object Types - Icinga 2
Elasticsearch Writer:
object ElasticsearchWriter “elasticsearch” {
  • host = “0.0.0.0”*
  • port = 9200*
  • index = “icinga2”*
  • enable_send_perfdata = true*
  • flush_threshold = 1024*
  • flush_interval = 10s*
Error Shown in Icinga2 Logs
critical/ElasticsearchWriter: Error: ‘no handler found for uri [/icinga2-2022.08.03/doc/_bulk] and method [POST]’. Unexpected response code 400 from URL ‘http://0.0.0.0:9200/icinga2-2022.08.03/doc/_bulk
Best Regards,
Kashan
Hello @mohammadkashanzafar!
I’m afraid Icinga 2 doesn’t support ES 8+:
Best,
A/K
see
We have fixed it in 2.14.0, please try it out.
