I am looking for a solution to send performance data or metrics to Elastic.
Does anyone have a good tip for me what is the best to use?
I have already tried the icingabeat and elasticsearch writer.
icingabeat can not send any performance data and the elasticsearch writer is not compatible with an Elastic v8 -.-.
i know this issue and sorry, it is 1,5 years open. Not nice for a monitoring tool, which is used in enterprise environments.
Maybe is is only a little problem.
Maybe the problem is, that the Module try to create a index under the path “xxx/doc/_bulk”
Maybe “xxx/_doc” is correct under Elastic v8.
Not, that the issue is till open when Elastic v9 is released
