Hey Icinga community,
I’d like to share with you a problem about the Icinga2 API, after upgrading from 2.10 to 2.12.
I can easily reproduce it with the following command:
for ((i=1;i<=100;i++)); do curl -k -v "https://icinga.com:5665/v1";sleep 1; done
It generally fail after 10-20 call. Sometimes more, sometimes less. The curl command stucks on “* Trying a.b.c.d…”
I’ve checked the number of connection on the ApiListener with:
curl -s -u 'user:password' https://icinga.com:5665/v1/status/ApiListener?pretty=1' | jq '.results[0].status.api.http'
"clients": 452
As my infrastructure is loadbalanced on 2 Master servers, you can multiply this number x2.
Some more infos:
# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.12.3-1)
Copyright (c) 2012-2021 Icinga GmbH (https://icinga.com/)
System information:
Platform: Debian GNU/Linux
Platform version: 9 (stretch)
Kernel: Linux
Kernel version: 4.9.0-14-amd64
Architecture: x86_64
Build information:
Compiler: GNU 6.3.0
Build host: runner-hh8q3bz2-project-298-concurrent-0
OpenSSL version: OpenSSL 1.1.0l 10 Sep 2019
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
icinga2 daemon -C
[2021-01-14 22:35:00 +0100] information/cli: Icinga application loader (version: r2.12.3-1)
[2021-01-14 22:35:00 +0100] information/cli: Loading configuration file(s).
[2021-01-14 22:35:01 +0100] information/ConfigItem: Committing config item(s).
[2021-01-14 22:35:01 +0100] information/ApiListener: My API identity: icinga-master1.localdomain
[2021-01-14 22:35:11 +0100] information/WorkQueue: #4 (DaemonUtility::LoadConfigFiles) items: 0, rate: 9/s (540/min 540/5min 540/15min);
[2021-01-14 22:35:11 +0100] information/WorkQueue: #6 (ApiListener, RelayQueue) items: 0, rate: 0/s (0/min 0/5min 0/15min);
[2021-01-14 22:35:11 +0100] information/WorkQueue: #7 (ApiListener, SyncQueue) items: 0, rate: 0/s (0/min 0/5min 0/15min);
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 1 NotificationComponent.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 2121 Hosts.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 169 Downtimes.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 8 NotificationCommands.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 1 FileLogger.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 4862 Comments.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 20527 Notifications.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 1 IcingaApplication.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 74 HostGroups.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 3 EventCommands.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 575 Dependencies.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 1 CheckerComponent.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 13 Zones.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 13 Endpoints.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 1 ExternalCommandListener.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 1 IdoMysqlConnection.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 12 ApiUsers.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 1 ApiListener.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 299 CheckCommands.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 1 LivestatusListener.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 15 TimePeriods.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 1 UserGroup.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 5 Users.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 37816 Services.
[2021-01-14 22:35:25 +0100] information/ConfigItem: Instantiated 6 ServiceGroups.
[2021-01-14 22:35:26 +0100] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2021-01-14 22:35:26 +0100] information/cli: Finished validating the configuration file(s).
The API comes with a very basic configuration:
# cat /etc/icinga2/features-enabled/api.conf
object ApiListener "api" {
accept_config = true
accept_commands = true
I really don’t understand why the API stop to responds sometimes. Any idea?
Thanks!
Kevin
