Icinga Reporting Module
When are we expecting the release of Icinga Reporting module for web2.
think it will be done when its done. Meanwhile you can give the reporting module from the master of director a try.
But be aware that it is totaly unsupported: https://github.com/Thomas-Gelf/icingaweb2-module-reporting
Regards,
Carsten
first, please subscribe the one of the possibilities here to stay uptodate: Product & Development Updates
Second, I hear that Icinga Camp Berlin is a good source for product updates.
Third, don’t use modules marked as prototype - you’re on your own with them. Instead, look into alternatives listed here: SLA Reporting
Here you go: SLA Reporting (I’ve updated everything inside).
If you encounter problems, please open GitHub issues in the corresponding projects. Please also make sure to understand the “split” between reporting and idoreports - when we add IcingaDB as new data provider later on, this will also result in a new reports provider next to idoreports.
