See
for detailed instructions.
Please share your before/after time measurements here.
See
Hi @Al2Klimov,
here are my results in version 2.13.2 and 2.13.6:
Unfortunately somewhat sobering. Bernd Erk has mentioned in this year’s osmc that with the new version 2.13.6 the config reload has become about 30% faster.
Which is unfortunately not the case with me.
time icinga2 daemon -C
[2022-11-22 11:26:27 +0100] information/cli: Icinga application loader (version: r2.13.2-1)
real 0m13.148s
user 0m55.685s
sys 0m9.926s
time env LD_PRELOAD=/lib/x86_64-linux-gnu/libjemalloc.so.2 icinga2 daemon -C
[2022-11-22 11:28:23 +0100] information/cli: Icinga application loader (version: r2.13.2-1)
real 0m11.556s
user 0m49.510s
sys 0m9.848s
[2022-11-23 11:15:07 +0100] information/cli: Icinga application loader (version: r2.13.6-1)
real 0m13.642s
user 0m53.440s
sys 0m10.781s
[2022-11-23 11:15:25 +0100] information/cli: Icinga application loader (version: r2.13.6-1)
real 0m12.006s
user 0m49.974s
sys 0m10.586s
My Setup:
62824 Notifications
1 IcingaApplication
26740 Dependencies
69 HostGroups
1819 Hosts
1 FileLogger
21092 Downtimes
1 Influxdb2Writer
194 Comments
1 IdoMysqlConnection
1 CheckerComponent
333 Zones
333 Endpoints
5 ApiUsers
1 ApiListener
1 NotificationComponent
311 CheckCommands
22 UserGroups
19 ServiceGroups
11 TimePeriods
55 Users
19935 ScheduledDowntimes
29385 Services
4 NotificationCommands
Tried it on RHEL7.7 system with a quite outdated icinga2 (update incoming
Icinga application loader (version: 2.11.2-1)
# icinga2 feature list
Disabled features: compatlog debuglog elasticsearch gelf graphite opentsdb perfdata statusdata syslog
Enabled features: api checker command ido-mysql influxdb livestatus mainlog notification
40509 ScheduledDowntimes.
30012 Dependencies.
23182 Notifications.
17390 Services.
2576 Hosts.
1053 Downtimes.
341 CheckCommands.
229 Users.
129 ServiceGroups.
88 UserGroups.
81 Comments.
42 HostGroups.
10 ApiUsers.
9 NotificationCommands.
6 TimePeriods.
4 Zones.
3 Endpoints.
1 NotificationComponent.
1 LivestatusListener.
1 InfluxdbWriter.
1 IdoMysqlConnection.
1 IcingaApplication.
1 FileLogger.
1 ExternalCommandListener.
1 CheckerComponent.
1 ApiListener.
without:
real 0m22.024s
user 4m25.635s
sys 2m47.647s
with jemalloc
# time env LD_PRELOAD=/lib64/libjemalloc.so.1 icinga2 daemon -C
real 0m19.754s
user 4m13.474s
sys 3m15.749s
seems to not make any difference in this case.
will do another test once the system is updated ![]()
@berk has also clearly mentioned the non-reliability of benchmarks as such. Just to be clear (as he spoke based on my info and I’ve even made the performance improvement in the first place): The more apply rules like assign where host.name == "h" && service.name == "s" you have, the faster 2.13.6 is compared to 2.13.5.
Also your load time isn’t even 1/2 minute, why you’re reading the Icinga starts/restarts/reloads very slowly section? ![]()
Yes I know, in his eyes its about 90% faster ![]()
I have about 200 of your described assign where conditions. Yes our systemd reload is not that slow. But the wohle relad process is slow, see: Remote Icinga instance is not connectet to master - for a few minutes after reload
So I thought it should be at least a little bit faster and I’ll write it in here.
Instantiated 1 NotificationComponent.
Instantiated 1 LivestatusListener.
Instantiated 1 ExternalCommandListener.
Instantiated 1 CheckerComponent.
Instantiated 4 TimePeriods.
Instantiated 2 Users.
Instantiated 84430 Services.
Instantiated 75474 ScheduledDowntimes.
Instantiated 2 Zones.
Instantiated 4 NotificationCommands.
Instantiated 162678 Notifications.
Instantiated 2977 Hosts.
Instantiated 1 IcingaApplication.
Instantiated 18 HostGroups.
Instantiated 84430 Dependencies.
Instantiated 300 Comments.
Instantiated 10 EventCommands.
Instantiated 421799 Downtimes.
Instantiated 2 Endpoints.
Instantiated 1 FileLogger.
Instantiated 12 ApiUsers.
Instantiated 253 CheckCommands.
Instantiated 1 ApiListener.
Instantiated 1 IcingaDB.
Without:
real 4m7.549s
user 14m33.763s
sys 1m42.542s
With jemalloc:
real 2m15.408s
user 7m11.452s
sys 2m55.066s
Around 50% shaved off the startup time. Nice ![]()
Ubuntu 24.04 LTS
information/ConfigItem: Instantiated 132661 Notifications.
information/ConfigItem: Instantiated 7 NotificationCommands.
information/ConfigItem: Instantiated 1 IcingaApplication.
information/ConfigItem: Instantiated 57 HostGroups.
information/ConfigItem: Instantiated 8320 Hosts.
information/ConfigItem: Instantiated 3 Downtimes.
information/ConfigItem: Instantiated 1 FileLogger.
information/ConfigItem: Instantiated 1 IdoMysqlConnection.
information/ConfigItem: Instantiated 9 Zones.
information/ConfigItem: Instantiated 14 Endpoints.
information/ConfigItem: Instantiated 3 ApiUsers.
information/ConfigItem: Instantiated 1 ApiListener.
information/ConfigItem: Instantiated 383 CheckCommands.
information/ConfigItem: Instantiated 134 Users.
information/ConfigItem: Instantiated 110 UserGroups.
information/ConfigItem: Instantiated 108 ServiceGroups.
information/ConfigItem: Instantiated 14 TimePeriods.
information/ConfigItem: Instantiated 50594 Services.
information/ConfigItem: Instantiated 4 ScheduledDowntimes.
without
real 0m11.104s
user 1m10.220s
sys 0m1.945s
With
real 0m10.571s
user 1m6.519s
sys 0m1.663s
