Hi there,
I am new to Icinga2 and I need help with an issue. I successfully run Icinga2 (r2.10.2-1) on CentOS 7 with Icinga2web (2.6.2) and the director (1.6.0). I have more than 100 machines connected (with active checks) and the mostly monitored well. I checked the /var/log/icinga2/icinga2.log and I suggest, that it grows very fast to multiple GBs. When I took a like inside I recognized, that Icinga doing the connections to it´s client in the loop (I could not better explain it). The logfile always shows the same for every node (example for one node):
[2021-03-22 14:41:33 +0100] information/ApiListener: New client connection for identity 'node55268.domain.com' from [10.42.27.28]:57828 [2021-03-22 14:41:33 +0100] information/ApiListener: Sending config updates for endpoint 'node55268.domain.com' in zone 'node55268.domain.com'. [2021-03-22 14:41:33 +0100] information/ApiListener: Syncing configuration files for global zone 'director-global' to endpoint 'node55268.domain.com'. [2021-03-22 14:41:33 +0100] information/ApiListener: Finished sending config file updates for endpoint 'node55268.domain.com' in zone 'node55268.domain.com'. [2021-03-22 14:41:33 +0100] information/ApiListener: Syncing runtime objects to endpoint 'node55268.domain.com'. [2021-03-22 14:41:33 +0100] information/ApiListener: Finished syncing runtime objects to endpoint 'node55268.domain.com'. [2021-03-22 14:41:33 +0100] information/ApiListener: Finished sending runtime config updates for endpoint 'node55268.domain.com' in zone 'node55268.domain.com'.
This is happening for each node which is connected to Icinga.
Do you have an idea?
Jens
