Hi All,
I followed this guide: Ubuntu 18.04 Bionic Graphite Guide
I hope somebody can help me with this.
Situation:
No graphs found on Graphite module.
Tcpdump showing packets sent to port:2003
15:22:36.272747 IP 172.31.10.200.60984 > 172.31.10.200.2003: Flags [P.], seq 2966016196:2966016294, ack 3475333829, win 512, options [nop,nop,TS val 1628475914 ecr 1628466947], length 98
15:22:36.272756 IP 172.31.10.200.2003 > 172.31.10.200.60984: Flags [.], ack 98, win 511, options [nop,nop,TS val 1628475914 ecr 1628475914], length 0
15:22:36.272901 IP 172.31.10.200.60984 > 172.31.10.200.2003: Flags [P.], seq 98:194, ack 1, win 512, options [nop,nop,TS val 1628475914 ecr 1628475914], length 96
15:22:36.272906 IP 172.31.10.200.2003 > 172.31.10.200.60984: Flags [.], ack 194, win 511, options [nop,nop,TS val 1628475914 ecr 1628475914], length 0
15:22:41.786910 IP 172.31.10.200.60984 > 172.31.10.200.2003: Flags [P.], seq 290:378, ack 1, win 512, options [nop,nop,TS val 1628481428 ecr 1628475914], length 88
- Graphite web not showing folders on tree but showing data received on graphs (check image)
root@icinga2:/var/spool/icinga2/perfdata# icinga2 object list --type GraphiteWriter
Object ‘graphite’ of type ‘GraphiteWriter’:
% declared in ‘/etc/icinga2/features-enabled/graphite.conf’, lines 6:1-6:32
- __name = “graphite”
- enable_ha = false
- enable_send_metadata = false
- enable_send_thresholds = true
% = modified in ‘/etc/icinga2/features-enabled/graphite.conf’, lines 9:3-9:31 - host = “172.31.10.200”
% = modified in ‘/etc/icinga2/features-enabled/graphite.conf’, lines 7:3-7:24 - host_name_template = “icinga2.$host.name$.host.$host.check_command$”
- name = “graphite”
- package = “_etc”
- port = “2003”
% = modified in ‘/etc/icinga2/features-enabled/graphite.conf’, lines 8:3-8:13 - service_name_template = “icinga2.$host.name$.services.$service.name$.$service.check_command$”
- source_location
- first_column = 1
- first_line = 6
- last_column = 32
- last_line = 6
- path = “/etc/icinga2/features-enabled/graphite.conf”
- templates = [ “graphite” ]
% = modified in ‘/etc/icinga2/features-enabled/graphite.conf’, lines 6:1-6:32 - type = “GraphiteWriter”
- zone = “”
Performance Data enabled on system, host, services.
carbon listening
module configured
root@icinga2:/opt/graphite/webapp/graphite# whisper-info.py /var/lib/graphite/whisper/carbon/agents/icinga2/tcp/metricsReceived.wsp
maxRetention: 157680000
xFilesFactor: 0.5
aggregationMethod: average
fileSize: 1044040
Archive 0
retention: 2592000
secondsPerPoint: 60
offset: 40
Archive 1
retention: 157680000
secondsPerPoint: 3600
offset: 518440
What could I be missing?
is there any way to confirm writing is working ok?
Thanks in advance.
