Galera MySQL cluster with VIPs and HAProxy for IDO-Mysql and more
Author: @Carsten
Revision: v1.0
Tested with:
  • Icinga 2 v2.10.2-1
  • MariaDB 10.3.10
Table of Contents
Galera Cluster for IDO-Mysql and more
This howto will show you how to setup a three node Galera cluster with a
floating ip created by keepalived and HAProxy for a maximum availability
of MySQL connection for IDO-MySQL, Icingaweb2 and any other application
that uses a MySQL database like Director, Grafana and many more
Requirements
The Galera Cluster documentaion tell us we need a minimum of 3 nodes to
create a cluster. Each node should run on a seperate hardware and if
possible in three different data centers. But if you have only 2 it will
also work, but dont let them run on the same hardware or hypervisor.
For HAProxy we create 2 a node “cluster” also for maximum availability ,
if you have 3 data centers you can extend it easily to 3 nodes.
SELinux & Firewall
This howto has SELinux and firewalls on the nodes disabled. If you want
to use them, its up to you to read the
Galera Documentation
about it
Nodes
For our installation edit the table of nodes below to fit your needs, you will need it later for the cluster
configuration.
DataCenter Server/Hypervisor Node Node Name IP
DC1 ProxMox01 MariaDB-Node01 192.168.178.55
DC2 ProxMox02 MariaDB-Node02 192.168.178.56
DC2 ProxMox03 MariaDB-Node03 192.168.178.57
DC1 ProxMox01 HAProxy01 192.168.178.58
DC2 ProxMox02 HAProxy02 192.168.178.59
DC1 HAProxy01 HAProxy-VIP1 192.168.178.60
DC2 HAProxy02 HAPeoxy-VIP2 192.168.178.61
Install & configure Galera Cluster
Enable Mariadb Repository
On each MariaDB node enable the repository that fits to your linux distribution, you can use the
MariaDB repository tool,
this how will use CentOS 7 (x86_64).
(Image 2)
Install MariaDb & Galera cluster filesets
Use the packet installer tool of your linux distribution, for CentOS this will install MariaDB and Galera cluster
yum install -y mariadb-server mariadb-client
Firstime start of MariaDB & secure setup
On each node start MariaDB and run the secure installation script. Answer all questions with yes and set the same root
password on all nodes.
[root@mariadb03 ~]# systemctl start mariadb
[root@mariadb03 ~]# mysql_secure_installation
NOTE: RUNNING ALL PARTS OF THIS SCRIPT IS RECOMMENDED FOR ALL MariaDB
      SERVERS IN PRODUCTION USE!  PLEASE READ EACH STEP CAREFULLY!
In order to log into MariaDB to secure it, we'll need the current
password for the root user.  If you've just installed MariaDB, and
you haven't set the root password yet, the password will be blank,
so you should just press enter here.
Enter current password for root (enter for none):
OK, successfully used password, moving on...
Setting the root password ensures that nobody can log into the MariaDB
root user without the proper authorisation.
Set root password? [Y/n]
New password:
Re-enter new password:
Password updated successfully!
Reloading privilege tables..
 ... Success!
By default, a MariaDB installation has an anonymous user, allowing anyone
to log into MariaDB without having to have a user account created for
them.  This is intended only for testing, and to make the installation
go a bit smoother.  You should remove them before moving into a
production environment.
Remove anonymous users? [Y/n]
 ... Success!
Normally, root should only be allowed to connect from 'localhost'.  This
ensures that someone cannot guess at the root password from the network.
Disallow root login remotely? [Y/n]
 ... Success!
By default, MariaDB comes with a database named 'test' that anyone can
access.  This is also intended only for testing, and should be removed
before moving into a production environment.
Remove test database and access to it? [Y/n]
 - Dropping test database...
 ... Success!
 - Removing privileges on test database...
 ... Success!
Reloading the privilege tables will ensure that all changes made so far
will take effect immediately.
Reload privilege tables now? [Y/n]
 ... Success!
Cleaning up...
All done!  If you've completed all of the above steps, your MariaDB
installation should now be secure.
Thanks for using MariaDB!
After this setup on each node you can stop MariaDB again on each node with
systemctl stop mariadb
Configure the Galera cluster
Edit on each node the mysql configuration (my.cnf), for Centos 7 the file is /etc/my.cnf.d/server.cnf. On each node
replace the ip of bind-address and wsrep_node_address to the ip of the node. Also replace wsrep_node_name with the
hostname of the node.
# These groups are read by MariaDB server.
# Use it for options that only the server (but not clients) should see
# See the examples of server my.cnf files in /usr/share/mysql/
# this is read by the standalone daemon and embedded servers
[server]
# this is only for the mysqld standalone daemon
[mysqld]
#Bind MariaDB daemon to the ip of the cluster node we use
bind-address=192.168.178.55
max_allowed_packet = 16M
[galera]
binlog_format=ROW
default-storage-engine=innodb
innodb_autoinc_lock_mode=2
query_cache_size=16M
query_cache_type=0
innodb_flush_log_at_trx_commit=0
innodb_buffer_pool_size=256M
#Galera settings
wsrep_on=ON
wsrep_provider=/usr/lib64/galera/libgalera_smm.so
wsrep_sst_method=rsync
wsrep_slave_threads=2
#SSL for Galera
#wsrep_provider_options="socket.ssl_key=/etc/mysql/ssl/server-key.pem;socket.ssl_cert=/etc/mysql/ssl/server-cert.pem;socket.ssl_ca=/etc/mysql/ssl/ca-cert.pem"
#Node name and ip
wsrep_node_address='192.168.178.55'
wsrep_node_name='mariadb01'
#Gluster name and node ips
wsrep_cluster_name='MariaDB_Cluster'
wsrep_cluster_address='gcomm://192.168.178.55,192.168.178.56,192.168.178.57'
[embedded]
# This group is only read by MariaDB servers, not by MySQL.
# If you use the same .cnf file for MySQL and MariaDB,
# you can put MariaDB-only options here
[mariadb]
# This group is only read by MariaDB-10.3 servers.
# If you use the same .cnf file for MariaDB of different versions,
# use this group for options that older servers don't understand
[mariadb-10.3]
Cluster tunings (not MySQL tunings)
To get the cluster as fast as possible, i recomend to use this settings:
innodb_flush_log_at_trx_commit=0 Ensure that the InnoDB log buffer is written to file once per second, rather than on
each commit, to improve performance. Read more about this at the Galera Documentation
In short you can loose up to 1 second of transaction in case of node crash or data center outtake. But you can recover
this data from other nodes (that hopefully did not go down at the same time).
wsrep_slave_threads=2 Set this variable to twice the number of CPU cores of your node. For example your node has 4
cpu, you set this to 8. This will speed up data replication between all cluster nodes
Creating the cluster
Starting the first node
depending on your linux distribution yo have to read the
documentation on howto start the first node.
For CentOS 7 it is:
galera_new_cluster
you can check the clustersize with
[root@mariadb01 ~]# mysql -u root -p -e "SHOW STATUS LIKE 'wsrep_cluster_size';"
Enter password:
| Variable_name      | Value |
| wsrep_cluster_size | 1     |
Cluster node 1 is up and running if you get the same output.
Adding the other nodes
If the first node is up and running we can add the other nodes with a
simple
[root@mariadb02 ~]# systemctl stop mariadb
[root@mariadb02 ~]# systemctl start mariadb
You can control the clustersize again with:
[root@mariadb02 ~]# mysql -u root -p -e "SHOW STATUS LIKE 'wsrep_cluster_size';"
Enter password:
| wsrep_cluster_size | 2     |
If cluster size is now 2, you can repeat this steps on cluster node 3 Now your cluster is up and running, you can use it
from every node as you would do it with a single database server.
Recovery from failed nodes/cluster
Single node failed/crashed/went down
If a node is crashed/failed and at least one other Galera cluster node is still up and running, you can recover the
failed/crashed nodes by just starting it up again with
After it started up you can check the cluster size with
Enter password:
All nodes failed/crashed/went down at the sametime
If all nodes went down, you have to check the file /var/lib/mysql/grastate.dat on each node. The node which contins the
line safe_to_bootstrap: 1 can be started as first node again with
galera_new_cluster
Check the cluster size is 1 before you start the other nodes.
All nodes failed/crashed/went down at the sametime and no node has safe_to_bootstrap: 1
If there is no safe_to_bootstrap: 1 on any node you have to get the node with the highest recovered position number
with:
[root@mariadb02 ~]# sudo -u mysql mysqld --wsrep-recover
2018-11-14 21:54:13 0 [Note] mysqld (mysqld 10.3.10-MariaDB) starting as process 12633 ...
2018-11-14 21:54:13 0 [Warning] Could not increase number of max_open_files to more than 1024 (request: 4182)
2018-11-14 21:54:13 0 [Warning] Changed limits: max_open_files: 1024  max_connections: 151 (was 151)  table_cache: 421 (was 2000)
2018-11-14 21:54:13 0 [Note] InnoDB: Using Linux native AIO
2018-11-14 21:54:13 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2018-11-14 21:54:13 0 [Note] InnoDB: Uses event mutexes
2018-11-14 21:54:13 0 [Note] InnoDB: Compressed tables use zlib 1.2.7
2018-11-14 21:54:13 0 [Note] InnoDB: Number of pools: 1
2018-11-14 21:54:13 0 [Note] InnoDB: Using SSE2 crc32 instructions
2018-11-14 21:54:13 0 [Note] InnoDB: Initializing buffer pool, total size = 256M, instances = 1, chunk size = 128M
2018-11-14 21:54:13 0 [Note] InnoDB: Completed initialization of buffer pool
2018-11-14 21:54:13 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2018-11-14 21:54:13 0 [Note] InnoDB: 128 out of 128 rollback segments are active.
2018-11-14 21:54:13 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2018-11-14 21:54:13 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2018-11-14 21:54:13 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2018-11-14 21:54:13 0 [Note] InnoDB: Waiting for purge to start
2018-11-14 21:54:13 0 [Note] InnoDB: 10.3.10 started; log sequence number 1653816; transaction id 1795
2018-11-14 21:54:13 0 [Warning] InnoDB: Skipping buffer pool dump/restore during wsrep recovery.
2018-11-14 21:54:13 0 [Note] Plugin 'FEEDBACK' is disabled.
2018-11-14 21:54:13 0 [Note] Server socket created on IP: '192.168.178.56'.
2018-11-14 21:54:13 0 [Note] WSREP: Recovered position: d542f659-e84b-11e8-a3c0-63d807a1f547:0
Start the Galera cluster on the node with the highest recoverd position
with
galera_new_cluster
and all the other nodes with
More information on howto recover failed nodes/clusters can be found in the
recovery documentation
Do’s and dont’s
  • Never ever set MariaDB to autostart on node startup.
  • Never stop all nodes at the same time
  • Read the documentation
  • Before you change anything to a MariaDB cluster/node make a fresh
    backup
  • Cluster is not a backup, create backups of your databases regulary
  • Asking someone for help is not a shame
Floating IPs (VIP)
For each data center we will create 1 floating IP to have the connectios as near as possible for each Icinga2 master
server. Keepalived will do the job for us and move the VIPs if needed.
Install keepalived
for CentOS 7 you can install it with
yum -y install keepalived
Configuration
We will configure each node without any iptable rules and a simple watch script to drop VIPs if HAProxy is not running.
Each Node will get one VIP that will be always on that node if HAProxy is also up and running.
Node 1: keepalived configuration
Change the routerid to match your host name, interface on both entries to match your interface name and also the
virtual_ipaddresses to match your environment (did you use your table from above?)
! Configuration File for keepalived
linkbeat_use_polling
global_defs {
   router_id haproxy01
   vrrp_skip_check_adv_addr
   vrrp_strict
   vrrp_garp_interval 0
   vrrp_gna_interval 0
   vrrp_iptables
vrrp_script chk_haproxy {
        script "pidof haproxy"
        interval 2
vrrp_instance VIP_1 {
    state MASTER
    interface ens32
    virtual_router_id 51
    priority 100
    advert_int 1
    authentication {
        auth_type PASS
        auth_pass 1111
    track_script {
        chk_haproxy
    virtual_ipaddress {
        192.168.178.60/24
vrrp_instance VIP_2 {
    state BACKUP
    interface ens32
    virtual_router_id 52
    priority 50
    advert_int 1
    authentication {
        auth_type PASS
        auth_pass 2222
    track_script {
        chk_haproxy
    virtual_ipaddress {
        192.168.178.61/24
Node 2: keepalived configuration
Change the routerid to match your host name and also the virtual_ipaddresses to match your environment (did you use
global_defs {
   router_id haproxy02
   vrrp_strict
   vrrp_gna_interval 0
   vrrp_iptables
        interval 1
    state BACKUP
    interface ens32
    priority 50
    advert_int 1
    authentication {
        auth_type PASS
        auth_pass 1111
    track_script {
        chk_haproxy
    virtual_ipaddress {
        192.168.178.60/24
    state MASTER
    interface ens32
    priority 100
    advert_int 1
    authentication {
        auth_type PASS
        auth_pass 2222
    track_script {
        chk_haproxy
    virtual_ipaddress {
        192.168.178.61/24
Enable & check if keepalived is working
Simple enable and start keepalived with (for CentOS 7):
systemctl enable keepalived
systemctl start keepalived
If you do ip addr show on your console, you will not see any of the VIPs we configured, because HAProxy is not
running. You can check if keepalived is up add running with systemctl status keepalived
[root@haproxy01 ~]# systemctl status keepalived
â—Ź keepalived.service - LVS and VRRP High Availability Monitor
   Loaded: loaded (/usr/lib/systemd/system/keepalived.service; disabled; vendor preset: disabled)
   Active: active (running) since Sun 2018-11-18 12:54:02 CET; 43min ago
  Process: 1546 ExecStart=/usr/sbin/keepalived $KEEPALIVED_OPTIONS (code=exited, status=0/SUCCESS)
 Main PID: 1547 (keepalived)
   CGroup: /system.slice/keepalived.service
           ├─1547 /usr/sbin/keepalived -D
           ├─1548 /usr/sbin/keepalived -D
           └─1549 /usr/sbin/keepalived -D
Nov 18 13:36:48 haproxy01 Keepalived_vrrp[1549]: /usr/sbin/pidof haproxy exited with status 1
Nov 18 13:36:50 haproxy01 Keepalived_vrrp[1549]: /usr/sbin/pidof haproxy exited with status 1
Nov 18 13:36:52 haproxy01 Keepalived_vrrp[1549]: /usr/sbin/pidof haproxy exited with status 1
Nov 18 13:36:54 haproxy01 Keepalived_vrrp[1549]: /usr/sbin/pidof haproxy exited with status 1
Nov 18 13:36:56 haproxy01 Keepalived_vrrp[1549]: /usr/sbin/pidof haproxy exited with status 1
Nov 18 13:36:58 haproxy01 Keepalived_vrrp[1549]: /usr/sbin/pidof haproxy exited with status 1
Nov 18 13:37:00 haproxy01 Keepalived_vrrp[1549]: /usr/sbin/pidof haproxy exited with status 1
Nov 18 13:37:02 haproxy01 Keepalived_vrrp[1549]: /usr/sbin/pidof haproxy exited with status 1
Nov 18 13:37:04 haproxy01 Keepalived_vrrp[1549]: /usr/sbin/pidof haproxy exited with status 1
Nov 18 13:37:06 haproxy01 Keepalived_vrrp[1549]: /usr/sbin/pidof haproxy exited with status 1
HAProxy for IDO-MySQL (or more)
HAProxy will keep an eye on which MariaDB node is up and can be connected for you. We can also do a litle manual load balancing for connectios from Icingaweb2, Director, Grafana etc. We want to keep connections as short (or fast) as possible, so from each HAProxy we use always the nearest MariaDB node to connect to for the IDO-MySQL connection.
In our howto the haproxy would connect mariadb01 node and use the others only if this node fails. HAProxy 2 will use mariadb02 and the others as backup. For manual load balancing we will have Icingaweb2 read from the IDO-MySQL from another node then the Icinga2 master2 will write to.
Requisite
We need a mysql user without a password, so HAProxy can check if it could login! Login into mysql and create a
user named haproxy for each HAProxy node with
CREATE USER 'haproxy'@'192.168.178.58';
CREATE USER 'haproxy'@'192.168.178.59';
Since we have already a working cluster, this have to be done only once on a node of your choice :slight_smile:And if someone from
your security team now yells “Users need a password!”, tell them that a) HAProxy only tests if login is possible b) has
no rights on anything
Installation of HAProxy
For CentOS 7 the newest version of HAproxy can be found in the Software Collection so first we have to install and
enable the repository. If you dont want this repo, you can also use the provided 1.5 version of haproxy.
yum -y install centos-release-scl
Now we can ionstall HAproxy with
yum -y install rh-haproxy18
Configuration
If you want to know more about the HAProxy, please visit the homepage of HAProxy.
Node HAProxy01
Edit the file
/etc/opt/rh/rh-haproxy18/haproxy/haproxy.cfg (can differ on other distros)
# Example configuration for a possible web application.  See the
# full configuration options online.
#   http://haproxy.1wt.eu/download/1.8/doc/configuration.txt
# Global settings
global
    # to have these messages end up in /var/opt/rh/rh-haproxy18/log/haproxy.log you will
    # need to:
    # 1) configure syslog to accept network log events.  This is done
    #    by adding the '-r' option to the SYSLOGD_OPTIONS in
    #    /etc/sysconfig/syslog
    # 2) configure local2 events to go to the /var/opt/rh/rh-haproxy18/log/haproxy.log
    #   file. A line like the following can be added to
    #    local2.*                       /var/opt/rh/rh-haproxy18/log/haproxy.log
    log         127.0.0.1 local2
    chroot      /var/opt/rh/rh-haproxy18/lib/haproxy
    pidfile     /var/run/rh-haproxy18-haproxy.pid
    maxconn     4000
    user        haproxy
    group       haproxy
    daemon
    # turn on stats unix socket
    stats socket /var/opt/rh/rh-haproxy18/lib/haproxy/stats
    # utilize system-wide crypto-policies
    ssl-default-bind-ciphers PROFILE=SYSTEM
    ssl-default-server-ciphers PROFILE=SYSTEM
# common defaults that all the 'listen' and 'backend' sections will
# use if not designated in their block
defaults
    mode                    http
    log                     global
    option                  httplog
    option                  dontlognull
    option http-server-close
    option forwardfor       except 127.0.0.0/8
    option                  redispatch
    retries                 3
    timeout http-request    10s
    timeout queue           1m
    timeout connect         10s
    timeout client          1m
    timeout server          1m
    timeout http-keep-alive 10s
    timeout check           10s
    maxconn                 3000
# Statistics page
listen stats
    bind *:8080
    stats enable
    stats uri /stats
    stats realm "HAProxy Statistics"
    stats refresh 5
    stats auth haadmin:password
    stats admin if TRUE
# MariaDB Frontend for Icinga2_ido
frontend icinga2_ido
    bind *:3306
    mode tcp
    option tcplog
    default_backend icinga2_ido
# MariaDB backend for Icinga2_ido
backend icinga2_ido
    mode tcp
    option tcplog
    option tcpka
    option mysql-check user haproxy
    balance source
    server mariadb01 192.168.178.55:3306 check weight 1 inter 5s rise 2 fall 2
    server mariadb02 192.168.178.56:3306 check weight 2 inter 5s rise 2 fall 2 backup
    server mariadb03 192.168.178.57:3306 check weight 3 inter 5s rise 2 fall 2 backup
# MariaDB Frontend for Director
frontend director
    bind *:3307
    mode tcp
    option tcplog
    default_backend director
# MariaDB backend for Director
backend director
    mode tcp
    option tcplog
    option tcpka
    balance source
    server mariadb01 192.168.178.55:3306 check weight 3 inter 5s rise 2 fall 2 backup
    server mariadb03 192.168.178.57:3306 check weight 1 inter 5s rise 2 fall 2
# MariaDB Frontend Read mostly (Icingaweb2 + Icingaweb2 IDO + Grafana)
frontend mysqlread
    bind *:3308
    mode tcp
    option tcplog
    default_backend mysqlread
# MariaDB backend Read mostly (Icingaweb2 + Icingaweb2 IDO + Grafana)
backend mysqlread
    mode tcp
    option tcplog
    option tcpka
    balance roundrobin
    server mariadb01 192.168.178.55:3306 weight 2 check inter 5s rise 2 fall 2
    server mariadb02 192.168.178.56:3306 weight 3 check inter 5s rise 2 fall 2
    server mariadb03 192.168.178.57:3306 weight 1 check inter 5s rise 2 fall 2
Node HAProxy02
Edit the file /etc/opt/rh/rh-haproxy18/haproxy/haproxy.cfg (can differ on other distros)
# Global settings
global
    # need to:
    maxconn     4000
    user        haproxy
    group       haproxy
    daemon
defaults
    mode                    http
    log                     global
    option                  httplog
    option                  dontlognull
    option                  redispatch
    retries                 3
    timeout queue           1m
    timeout connect         10s
    timeout client          1m
    timeout server          1m
    timeout check           10s
    maxconn                 3000
# Statistics page
listen stats
    bind *:8080
    stats enable
    stats uri /stats
    stats refresh 5
    stats admin if TRUE
    bind *:3306
    mode tcp
    option tcplog
backend icinga2_ido
    mode tcp
    option tcplog
    option tcpka
    balance source
    server mariadb01 192.168.178.55:3306 check weight 2 inter 5s rise 2 fall 2 backup
    server mariadb02 192.168.178.56:3306 check weight 1 inter 5s rise 2 fall 2
frontend director
    bind *:3307
    mode tcp
    option tcplog
backend director
    mode tcp
    option tcplog
    option tcpka
    balance source
frontend mysqlread
    bind *:3308
    mode tcp
    option tcplog
backend mysqlread
    mode tcp
    option tcplog
    option tcpka
    balance roundrobin
    server mariadb01 192.168.178.55:3306 weight 1 check inter 5s rise 2 fall 2
    server mariadb03 192.168.178.57:3306 weight 2 check inter 5s rise 2 fall 2
Enable & start of HAProxy
systemctl enable rh-haproxy18-haproxy
systemctl start rh-haproxy18-haproxy
Now you will see that the VIPs are up with:
[root@haproxy01 ~]# ip addr show
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: ens32: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 00:0c:29:69:e9:07 brd ff:ff:ff:ff:ff:ff
    inet 192.168.178.58/24 brd 192.168.178.255 scope global noprefixroute ens32
    inet 192.168.178.60/24 scope global secondary ens32
    inet6 2a02:8070:2199:5700:20c:29ff:fe69:e907/64 scope global noprefixroute dynamic
       valid_lft 6888sec preferred_lft 3288sec
    inet6 fe80::20c:29ff:fe69:e907/64 scope link noprefixroute
Stats Webinterface
Now you can check the statistic of HAProxy in your browser http://192.168.178.60:8080/stats and
http://192.168.178.61:8080/stats
On haproxy01 it will looke like
And haproxy02 like
The diffrence is which mariadb node will be used first before the others.
Use the VIPs for Icinga2, Icingaweb2, Director etc.
Now that we have the MariaDB cluster, 2 VIPs and HAProxy up and running, we need to configure Icinga2, Icingaweb2,
DIrector etc. to use it.
Icinga2 IDO-MySQL
Setup the database as written in the setup documentation
Master 1
 * The db_ido_mysql library implements IDO functionality
 * for MySQL.
library "db_ido_mysql"
object IdoMysqlConnection "ido-mysql" {
  user = "icinga"
  password = "secret"
  host = "192.168.178.60"
  database = "icinga"
Master 2
 * for MySQL.
  user = "icinga"
  password = "secret"
  host = "192.168.178.61"
  database = "icinga"
Icingaweb2 Resources
Either you configure your Icingaweb2 database and ido-mysql connection during the setup or you modify the ini file directly.
Edit the file /etc/icingaweb2/resources.ini and change/add
Icingaweb2
[icingaweb_db]
type = "db"
db = "mysql"
port = "3308"
dbname = "icingaweb2"
username = "icingaweb2"
password = "secret"
charset = ""
persistent = "0"
Icingaweb2 IDO-Mysql
[icinga_ido]
type = "db"
db = "mysql"
port = "3308"
dbname = "icinga"
username = "icinga"
password = "secret"
charset = ""
persistent = "0"
Director
[director-db]
type = "db"
db = "mysql"
port = "3307"
dbname = "director"
username = "director"
password = "secret"
charset = "utf8"
ToDo
  • Documentation for other Linux distros
  • Failover test documentation
  • Monitoring IDO Cluster
  • Monitor VIPs
  • Monitor HAProxy
Files
Network diagram for use with draw.io
Galera_Cluster_with_HAProxy.zip (2.1 KB)
This is just awesome! I was preparing something very similar in most of the parts.
Deviations would be:
  • everything is hosted at DigitalOcean and I use keepalived to trigger a failover of the floating IP
  • additional vrrp_scripts to do a mysql query (basically functional check of haproxy & a get to the icinga2 API
  • use rsync to sync /etc/icingaweb2 as there is no option for shared storage or something like that
  • haproxy is just used to balance queries to the mariadb / galera backend:
listen galera-cluster
    bind 127.0.0.1:3306
    mode tcp
    option mysql-check user haproxy_checks
    balance roundrobin
    server do-ffm-galera01 10.10.117.123:3306 check
    server do-ffm-galera02 10.10.117.124:3306 check
    server do-ffm-galera03 10.10.117.125:3306 check
Now I’m wondering if it still makes sense to have it in my own post or if I just add it to your one. A whole bunch of content would be duplicate and having it in just one thread probably makes it easier to keep it up-to-date.
Howtos are always opinionated, and it doesn’t hurt to have more of them following different setup requirements. I’d appreciate yours too :slight_smile:
Just make sure that round robin is used for read queries mostly and stick write queries to one of the cluster nodes.
hi,
we use Consul and a services to create our HAproxy configuration. So, if one node goes down, Consul (and the haproxy consul template) removes the dead node out of the balancer pool.
I had also a nice effect with the Mariadb part: My primary MariaDB was running out of diskspace very quickly, because of binlogs. That had the effect, that MariaDB-01 was from the Consul / HAproxy side working and SELECTS where OK, but UPDATE/INSERT not.
Both Icinga2 masters were not able to write anything to the IDO and then both icinga2 processes died (out-of-memory).
Had the same learning regarding the binlogs.
Just 2 notes how we handled it:
1st: adapt the configuration parameter expire_logs_days in the MySQL configuration to your environments and needs
2nd: You might want to store the bin logs on a dedicated device which can be helpful as part of the disaster recovery operations if the VM itself crashed.
hi,
I had both set: expire_logs_days = 7 (I used than 1) and device also different one, but MariaDB has written several GB per day(!) :smiley:
