I understand that by design Icinga will execute one NotificationCommand per user listed into a notification instance.
But is it possible to ask Icinga to execute the notificationCommand only once per notification and get the related users with his custom attributes using runtime macros or similar?
Well, there are some situations that I want to control:
Grant to the notificationCommand’s script the control logic to distribute the list of emails per user instead of the Icinga Notification system.
Sometimes I want to join all the users address and send them in just one mail. I know that is posible making a notification instance with just one user with multiple addresses. But in that case I’m losing the opportunity to describe each address’ origin and see them from Icingaweb in the host/service’s history.
In some other cases I need to perform some actions one time per notification before sending the mail, but in the actual scenario, if a notification instance has 3 users, then those actions will repeat 3 times making incidents difficult to control.
ok, then you’d need a “dummy” notification, command and user which fires a script for implementing the logic.
The rest requires some advanced programming techniques inside the DSL, or you’ll manage the user details as custom attribute statically inside e.g. the notification, or dummy user object.
Static details
apply Notification "..." to Service {
vars.involved_users = {
"michi" = "michael@domain.com"
"patricio" = "patricio@domain.com"
Having a dictionary or an array will require you to dump that in a certain way, best would be JSON as string which your script then can read.
The above NotificationCommand can be re-used for this.
object User "michi" {
email = "michael@domain.com"
object User "patricio" {
email = "patricio@domain.com"
vars.involved_users = {{
var res = {}
for (u in get_objects(User)) {
if (match("*@domain.com", u.email)) {
res[u.name] = u.email
return res
The above may also be abstracted directly into the NotificationCommand object in the vars.users attribute.
Now, i can join all the users address and send them in just one mail. But, I found that four notifications would be sent when there were four recipients, although join all the users address.
In the above scenario, is there any way to send a notification only once?
I would appreciate any help, thanks.
# notification
apply Notification "smartcall-search" to Service {
users = service.vars.search_notification.first.smartcall.users
user_groups = service.vars.search_notification.first.smartcall.groups
var res = []
if (service.vars.search_notification.first.smartcall.users){
for (name in service.vars.search_notification.first.smartcall.users){
for (u in get_objects(User)){
if (u.name == name){
var temp = {}
temp[u.name] = u.pager
res += [temp]
if (service.vars.search_notification.first.smartcall.groups){
for (group in service.vars.search_notification.first.smartcall.groups){
if (group in u.groups){
var temp = {}
res += [temp]
return res
command = "smartcall-service-notification"
states = [ Critical ]
types = [ Problem ]
interval = service.vars.notification_interval.smartcall
period = "24x7"
assign where service.vars.search_notification.first.smartcall
In the log, we can see that the notification command will be run two times because there are two smartcall users. But i have joined all the users address and send them in just one time, so i hope the notification command is run olny one times. What should i can do?
how to configure “one dummy user” that you say , which can surpass the validation and can join all the users address and send them in just one notification?
