Duplicate host entry points to self when adding agent
Thank you everyone taking a look at this.
I’m trying to add a single agent “icinga-agent.internal.example.com” to a single master “icinga.hq”. I have completed exchanging cert information, added the zones and endpoints successfully, and am stuck adding the hosts.conf for remote command execution. I am following the documentation in Distributed Monitoring - Icinga 2 . I keep getting an error:
[2021-04-27 13:30:13 -0400] critical/config: Error: Object ‘icinga-agent.internal.example.com’ of type ‘Host’ re-defined: in /etc/icinga2/zones.d/master/hosts.conf: 13:1-13:52; previous definition: in /etc/icinga2/zones.d/master/hosts.conf: 13:1-13:52
object Host “icinga-agent.internal.example.com” {
import “my-linux-host”
address = “10.2.2.3”
vars.agent_endpoint = name
There are no other host object definitions in any .conf file for ‘icinga-agent.internal.example.com’.
I have the following in my /etc/icinga2/icinga2.conf:
include “zones.conf”
include_recursive “zones.d”
// include_recursive “conf.d”
I have this host mentioned in the zones.conf file but as an Endpoint, not a Host object, and also as a Zone, following the documentation quite literally and just changing the host name.
Requested information:
/etc/icinga2/zones.conf:
object Endpoint “icinga.hq” {
host = “10.1.2.3”
object Endpoint “icinga-agent.internal.example.com” {
host = “10.2.2.3”
log_duration = 0 // Disable the replay log for command endpoint agents
object Zone “master” {
endpoints = [ “icinga.hq” ] //array with endpoint names
object Zone “icinga-agent.internal.example.com” {
endpoints = [ “icinga-agent.internal.example.com” ]
parent = “master” //establish zone hierarchy
global = true
# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.12.3-1)
Copyright (c) 2012-2021 Icinga GmbH (https://icinga.com/)
License GPLv2+: GNU GPL version 2 or later http://gnu.org/licenses/gpl2.html
System information:
Platform: Ubuntu
Platform version: 18.04.5 LTS (Bionic Beaver)
Kernel: Linux
Kernel version: 4.15.0-128-generic
Architecture: x86_64
Build information:
Compiler: GNU 8.4.0
Build host: runner-hh8q3bz2-project-298-concurrent-0
OpenSSL version: OpenSSL 1.1.1 11 Sep 2018
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
# icinga2 feature list
Disabled features: compatlog debuglog elasticsearch gelf graphite icingadb influxdb livestatus opentsdb perfdata statusdata syslog
Enabled features: api checker command ido-mysql mainlog notification
# icinga2 object list --type Endpoint
Object ‘icinga-agent.internal.example.com’ of type ‘Endpoint’:
% declared in ‘/etc/icinga2/zones.conf’, lines 12:1-12:56
  • __name = “icinga-agent.internal.example.com”
  • host = “10.202.244.125”
    % = modified in ‘/etc/icinga2/zones.conf’, lines 13:3-13:25
  • log_duration = 0
    % = modified in ‘/etc/icinga2/zones.conf’, lines 14:3-14:18
  • name = “icinga-agent.internal.example.com”
  • package = “_etc”
  • port = “5665”
  • source_location
    • first_column = 1
    • first_line = 12
    • last_column = 56
    • last_line = 12
    • path = “/etc/icinga2/zones.conf”
  • templates = [ “icinga-agent.internal.example.com” ]
    % = modified in ‘/etc/icinga2/zones.conf’, lines 12:1-12:56
  • type = “Endpoint”
  • zone = “”
Object ‘icinga.hq’ of type ‘Endpoint’:
% declared in ‘/etc/icinga2/zones.conf’, lines 8:1-8:27
  • __name = “icinga.hq”
  • host = “10.1.1.25”
    % = modified in ‘/etc/icinga2/zones.conf’, lines 9:3-9:20
  • log_duration = 86400
  • name = “icinga.hq”
  • package = “_etc”
  • port = “5665”
  • source_location
    • first_column = 1
    • first_line = 8
    • last_column = 27
    • last_line = 8
  • templates = [ “icinga.hq” ]
    % = modified in ‘/etc/icinga2/zones.conf’, lines 8:1-8:27
  • type = “Endpoint”
  • zone = “”
You explicitly included the already implicitly included zones.d, so removing this line from your icinga2.conf will solve the problem.
Thank you Dirk! That was the problem. Now I can move on.
I’m not a fan of implicit includes. I’m sure it’s documented somewhere, but a mix of explicit and implicit includes and special magic name directories leads to problems like this.
At least, if I see a duplicate error like this again, I’ll know it’s probably a duplicate include. (And I’ll pat myself on the back for including enough info to find the problem on the first go, LoL)
I totally understand that and have seen this error quite often because of this, but in this case it is required as it will load config directories dynamically based on zones configuration.
