Documentation for Distributed Monitoring with Director?
Hello All,
I am brand new to Icinga and having difficulty finding the resources I need to learn it. I am trying to ask around at all the places I can think of in hopes of getting an answer. Hopefully this is enough information to convey where I am at.
I am setting up distributed monitoring from scratch using three Icinga servers, 1 master and 2 satellites. Master in AWS, Satellite in AWS, Satellite on prem. I have made progress but am still unable to figure out how to get this setup properly. The documentation from Icinga doesnt seem to have anything on this. The closest thing I could find was this old guide from 2018. I am not looking to do any deep monitoring, just simple ping/ssh/winrm/http on a bunch of Ubuntu/AWS Linux/Windows 2012/2016/2019 servers. Unless I am missing something significant, I don’t see the need to deploy an “agent”(?) on our hosts given what we are trying to accomplish.
Due to me being so new I think I am not searching with the correct terminology and thus not getting any results. All I want to know is the following:
Am I right for assuming that the master server will not be performing any checks but rather receiving data from its satellites that have done the checks themselves?
How do I confirm that I have setup the Master / Satellite relationship properly? Is it just a matter of looking at each server’s zone files and if so what am I looking for?
How do I specify that Host A should be monitored by Satellite A and Host B should be monitored by Satellite B?
Any useful links, training videos, guides, etc would be extremely helpful.
Thanks everyone!
Hi @hewithaname,
Welcome to the community please read its guidelines:
https://community.icinga.com/guidelines
Have you seen this page:
I had a great succes setup up a cluster like yours using all the documentation on that page :slight_smile:
For a director approach see this also:
Hope it helps!
Hi @belastingvormulier,
Thanks for the quick response.
I have read through the Director documentation and there is not anything about how to actually use the Director to setup distributed monitoring.
As for the Distributed Monitoring page, I used that to setup the master satellite relationship between AWS and our main site…I think. That was why I asked the question about how to confirm that the relationship was setup correctly.
According to the documentation our setup should look something like this. I assume this is the zones.conf file? I am not sure since the documentation doesn’t include which files it is referring to:
object Endpoint "aws-master.domain" {
  host = "192.168.56.100"
object Endpoint "aws-satellite.domain" {
  host = "192.168.56.101"
object Endpoint "siteA-satellite.domain" {
  host = "10.10.10.100"
object Zone "master" {
  endpoints = [ "aws-master.domain" ]
object Zone "aws-satellite" {
  endpoints = [ "aws-satellite.domain" ]
  parent = "master"
object Zone "siteA-satellite" {
  endpoints = [ "siteA-satellite.domain" ]
  parent = "master"
Will all the configuration files on all of the servers need to be identical then? I assumed that was the main selling point of Director which is why I was using it. It uses an API user for each Icinga Server to ensure that all of the servers are configured correctly.
Each Icinga server is in its own Zone with satellites having their parent (zone) listed as the master (zone). The “endpoints” in each of these zones are the Icinga Servers themselves. So if I wanted this all setup then I would need to, add each icinga server as a host with a dummy template, add them as endpoints somehow, and then somehow set their parent zone to be the master while also setting the master as master?
Thanks!
hi @hewithaname,
Feel free to contribute to the documentation :slight_smile:
https://github.com/Icinga/icinga2/blob/master/CONTRIBUTING.md
It is opensource after all!
It looks indeed like a zone.conf
It would greatly help to comment in your code for example the zones.conf from my setup (which is the same but without director and a bit shortened) it will help you keep track of what is what.
// THIS FILE IS MANAGED BY ANSIBLE
// masters
object Endpoint "m1.internal" {
  host = "m1.internal"
  // This server
  • No, generally you configure things once in director or in configuration files on the master.
  • Keep things simple you have agents and servers naming your servers servers is confusing to read even for me :slight_smile:
  • so yes your agent has a zond of its own usually the agents hostname, and the zone of the master or satellite depending on the setup.
  • No, the agent has the agent (itself) and the icinga server above it (master or satellite)
  • This is a little confusing for me, perhaps you could rephrase this… you dont need a dummy template.
I absolutely plan on doing so. As soon as I figure all of this stuff out I will be writing a detailed guide on how I did it using my homelab as an example. I feel like the setup I am going for is what most people would use so I hope it helps.
Sorry about that. Like I said I am still trying to get the terminology correct so as to better communicate with you all. :slightly_smiling_face:
  • Node => an icinga instance
  • Endpoint => a device that is being monitored by a node like a windows or linux server
  • Master => a node that is running as master. If there is only one node then it is default master. Icinga can support up to two master’s in a zone and will handle the HA. A master has no parents
  • Satellite => a node in a zone (that is not the same zone as the master) that has a master zone as its parent and endpoints as its children
When it comes to the term agent though, I am unsure of what it means. In some documentation it uses the word agent in the context of installing an agent on a host and in others they use it to mean a satellite monitors an agent. So is an agent a piece of software that allows you to deep monitoring or is it a term that refers to clients you are monitoring (ie linux/windows servers)?
https://blog.sleeplessbeastie.eu/2018/02/05/how-to-setup-icinga2-master-satellite-client-using-director-module/
I used this guide to try and get this all setup. In the fourth screenshot where he appears to be adding the satellite node in as a host, he seems to add it to the “Dummy host template”. When I try and add hosts I have to always add them to a template of some sorts. That template then says what check_command is used (ie hostalive).
Great!
Right so technically for me a agent is the node that connects to the satellite (agent)
yes this is confusing as the termS agent and agent mean two different things and they are both right as there is also a agent on the master node :stuck_out_tongue: but we just call it the master
So I like to keep it simple
  • master
  • satelite (optional)
  • agent (the server you want to monitor)
Any how still does not solve your initial question I suppose!
back to post 1:
Yes, the the master receives the results, after it tels the satellite the configuration. The satellite will then as the agent to do the check :slight_smile:
zone files, configuration and logs mostly…
Bu putting them in the proper folder on the master in the /zones.d/zone_name this will go to the satellite, that goes to the agent. The agent needs to allow the satellites incoming connection in the configuration for it to work.
Hope it helps :slight_smile:
This is excellent information. I really appreciate you sticking with me on this and helping clear things up. I am starting to gain traction on all of this.
I have gone through the configuration both on the command line and through director and spotted a few mistakes I made. I have corrected them but I am still unable to get a successful ping/ssh/http/winrm check on a host that only the satellite should be able to ping/ssh/http/winrm. I have confirmed that I can ping the host in question from the satellite too. If I can get this demo host working then I can take everything I have learned and start applying it everywhere else.
I did everything through Director but I have been using the preview tab to see where it saves the files and then inspecting them on the command line to see what is going and to learn what it is that it does etc.
Here is what my dashboard is showing:
Here is what my config is showing:
root@AWS-NOC-02:/var/lib/icinga2/api/zones/WDC/director# cat host_templates.conf
template Host "WDC-basic-windows" {
    check_command = "hostalive"
    command_endpoint = "WDC-NOCSat-01"
template Host "WDC-switches" {
root@AWS-NOC-02:/var/lib/icinga2/api/zones/WDC/director# cat hosts.conf
object Host "WDC-NOCSat-01" {
    import "WDC-NOCSat-Template"
    display_name = "WDC Icinga Satellite"
    address = "192.100.34.190"
object Host "WDC333SW01" {
    import "WDC-switches"
    display_name = "Meraki Switch Test"
    address = "192.100.16.89"
object Host "WDC-BOUNCE-01" {
    import "WDC-basic-windows"
    display_name = "WDC-BOUNCE-01"
    address = "192.100.34.61"
root@AWS-NOC-02:/var/lib/icinga2/api/zones/WDC/director# cat servicesets.conf
 * Service Set: basic-windows-services
 * on host WDC-basic-windows
apply Service "check-ping" {
    import "check-ping"
    assign where "WDC-basic-windows" in host.templates
    zone = "WDC"
apply Service "check-winrm " {
    import "check-winrm "
    zone = "WDC"
So it would appear that these two test agents are being checked by the correct satellite which is good news. Assuming that my hosts are setup correctly, then that means I setup my services wrong?
cat /var/lib/icinga2/api/zones/director-global/director/service_templates.conf
template Service "check-ssh" {
    check_command = "ssh"
    command_endpoint = host_name
template Service "check-http" {
    check_command = "http"
template Service "check-ping" {
    command_endpoint = null
template Service "check-winrm " {
    check_command = "tcp"
    vars.tcp_port = "5985"
Other than check-ping being null I am not seeing anything that stands out?
cat /var/lib/icinga2/api/zones/director-global/director/servicesets.conf
 * Service Set: basic-linux-services
 * HTTP/PING/SSH
 * on host basic-linux
apply Service "check-http" {
    import "check-http"
    assign where "basic-linux" in host.templates
apply Service "check-ssh" {
    import "check-ssh"
    import "check-ping"
 * ping and winrm
 * Service Set: basic-ping
 * ping check
Hopefully I am troubleshooting this correctly. Its starting to all come together.
I was following this guide while doing this
Right so I you look at your screen shot, then you will see ping being “not connected”
Which is not typically the error message you get from a ping service. This indicates it is trying to connect to the agent WDC-BOUNCE-01 on the icinga proces and tries to ping it self which is in 100% of the cases not use-full :slight_smile:
You want the first piece of icinga infrastructure above the agent to ping the agent. (satellite or master)
So it being null in your config is definitely a problem here. (probably the same for winrm/ssh, not very use-full if the agent tries to check it self!)
Its kinda like having a doctor as a parent and googling your symptoms yourself and saying I am fine :smiley:
you switch seems to have the right ping source?
Any way hope it helps you a bit further dont forget to lurke on the OG documentation:
https://icinga.com/docs/director/latest/doc/24-Working-with-agents/
Good Afternoon William,
I hope you had a wonderful and safe Thanksgiving!
So your response brings us back full circle to my original desire of doing monitoring without having to go around and install the icinga agent on all of my hosts. I thought that the Satellites in the zones of the agents would be able to do the basic ssh/ping/http/winrm checks?
Hi No TG here in the EU but thanks for asking yourself?
I love a good circle :slight_smile:
Right so you could let your satellite do all the heavy lifting, If its a good thing to do ?
depends,
In any case you are looking for the command_endpoint setting there is one in your host template that you can set to your satellite that should give you the settings you want.
Quiet and peaceful :slightly_smiling_face:
So I am glad that you mentioned command_endpoint as I told my host template to use the Satellite but was unsure if it was the correct thing to do. Now I know it was which is good.
    import "wdc-basic-windows"
    address = "10.10.10.10"
cat /var/lib/icinga2/api/zones/AWS-NOC-02/director/endpoints.conf
object Endpoint "WDC-NOCSat-01" {
    host = "10.10.10.190"
I went to the Satellite and confirmed that the password in /etc/icinga2/conf.d/api-users.conf was correct
 * The APIUser objects are used for authentication against the API.
object ApiUser "WDC" {
  password = "SuperSecretPassword123!"
  // client_cn = ""
  permissions = [ "*" ]
I then took that password and verified on master that the API user had that password.
Not sure where else to look to be honest.
Hi There,
So I have done some digging in my configuration :slight_smile: (getting this to work for myself was quite something i do remember)
we offshore our “hostalive” to our satelite we do that by NOT setting command_endpoint for this particilar service and set it to
command_endpoint = host.vars.agent_endpoint
in our service template
which points to:
vars.agent_endpoint = name
in our host config
So in order to get the check to execute on your satellite for a service you need to either
for our satellite host we had to override to to the master
in the service template you would set:
vars.command_endpoint = "master"
Now this is all without the director :tada:
So I spun up my virtualbox for you and this is probably what you want to set to “no”
which generates:
template Service "test-s" {
(leaving it empty)
That should now trigger the check from the host above the agent (a satellite in your case)
Hope it helps, It did for me :smiley:
Good Morning!
I hope you had an excellent weekend.
So I tried to set this manually but after restarting the icinga service using systemctl restart icinga, director changed the file back. I guess this is to be expected and actually a good thing in a way. I poked around the WebUI but could not find any way to manually change this.
I am assuming that you are referring to /etc/icinga2/conf.d/hosts.conf. If so, I checked in there and I do not have vars.agent_endpoint = name set in that file. I will go ahead and add it.
object Host NodeName {
  /* Import the default host template defined in `templates.conf`. */
  import "generic-host"
  /* Specify the address attributes for checks e.g. `ssh` or `http`. */
  address = "127.0.0.1"
  address6 = "::1"
  /* Set custom attribute `os` for hostgroup assignment in `groups.conf`. */
  vars.os = "Linux"
  /* Define http vhost attributes for service apply rules in `services.conf`. */
  vars.http_vhosts["http"] = {
    http_uri = "/"
  /* Uncomment if you've sucessfully installed Icinga Web 2. */
  //vars.http_vhosts["Icinga Web 2"] = {
  //  http_uri = "/icingaweb2"
  /* Define disks and attributes for service apply rules in `services.conf`. */
  vars.disks["disk"] = {
    /* No parameters. */
  vars.disks["disk /"] = {
    disk_partitions = "/"
  /* Define notification mail attributes for notification apply rules in `notifications.conf`. */
  vars.notification["mail"] = {
    /* The UserGroup `icingaadmins` is defined in `users.conf`. */
    groups = [ "icingaadmins" ]
  /* For use with our service template */
(This change persisted through a restart probably because it is not in the “directory” folder (ie director doesnt control it))
Did you mean hosts config on your master and if not which configuration are you referring to?
root@AWS-NOC-02:~# locate hosts.conf
/var/lib/icinga2/api/packages/director/AWS-NOC-02-1606330592-0/zones.d/WDC/hosts.conf
/var/lib/icinga2/api/zones/WDC/director/hosts.conf
/var/lib/icinga2/api/zones/WDC/director/hosts.conf is the file that contains the configuration for the satellite
    address = "10.10.10.20"
Are you suggesting I change this to be
Although as I type this I am realizing that what I said above about director changing the file back when Icinga is restarted will probably also happen here. So no manual changes can be made to the files which is a bummer.
Regardless, after making the suggested change of setting run on agent to no on the service templates my service_templates.conf now looks like this
However it is still showing the master as the one doing the checks
I feel like we are really close to figuring this out. Each post gets me further and teaches me something new so again, thank you for all your help. I created a simulated multi-site setup on my homelab using firewall rules and vlans so that I can work through all of this from scratch and document the whole process. If you are alright with it, I plan on giving a special mention / shoutout to you at the bottom of each part of the guide so that if anyone ever reads my guide, they will know the true source of my knowledge :wink: .
Hi @hewithaname,
this:
Is great stuff. If you change the template to yes this will change for the specific service of your choosing, It should monitor your service on the specific host And that should be the end result you are looking for ?
That is the end result yes. So I changed the run on agent in check-ssh template to yes, I was able to deploy the configuration just fine.
zones.d/director-global/service_templates.conf
information/cli: Icinga application loader (version: r2.8.1-1)
information/cli: Loading configuration file(s).
information/ConfigItem: Committing config item(s).
information/ApiListener: My API identity: AWS-NOC-02
warning/ApplyRule: Apply rule 'check-http'
  (in [stage]/zones.d/director-global/servicesets.conf: 12:1-12:26) for type 'Service' does not match anywhere!
warning/ApplyRule: Apply rule 'check-ssh'
  (in [stage]/zones.d/director-global/servicesets.conf: 21:1-21:25) for type 'Service' does not match anywhere!
warning/ApplyRule: Apply rule 'check-ping'
  (in [stage]/zones.d/director-global/servicesets.conf: 30:1-30:26) for type 'Service' does not match anywhere!
information/ConfigItem: Instantiated 1 ApiListener.
information/ConfigItem: Instantiated 4 Zones.
information/ConfigItem: Instantiated 2 Endpoints.
information/ConfigItem: Instantiated 2 ApiUsers.
information/ConfigItem: Instantiated 1 FileLogger.
information/ConfigItem: Instantiated 13 Notifications.
information/ConfigItem: Instantiated 2 NotificationCommands.
information/ConfigItem: Instantiated 209 CheckCommands.
information/ConfigItem: Instantiated 1 Downtime.
information/ConfigItem: Instantiated 2 HostGroups.
information/ConfigItem: Instantiated 1 IcingaApplication.
information/ConfigItem: Instantiated 4 Hosts.
information/ConfigItem: Instantiated 2 Comments.
information/ConfigItem: Instantiated 1 UserGroup.
information/ConfigItem: Instantiated 1 User.
information/ConfigItem: Instantiated 3 TimePeriods.
information/ConfigItem: Instantiated 17 Services.
information/ConfigItem: Instantiated 3 ServiceGroups.
information/ConfigItem: Instantiated 1 ScheduledDowntime.
information/ConfigItem: Instantiated 1 CheckerComponent.
information/ConfigItem: Instantiated 1 ExternalCommandListener.
information/ConfigItem: Instantiated 1 IdoMysqlConnection.
information/ConfigItem: Instantiated 1 NotificationComponent.
information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
information/cli: Finished validating the configuration file(s).
I applied the same change to the check-http service template and that had the same result as above.
However, when I made the same changes to check-ping and check-winrm it failed with the following error:
critical/config: Error: Validation failed for object 'WDC-BOUNCE-01!check-ping' of type 'Service'; Attribute 'command_endpoint': Object 'WDC-BOUNCE-01' of type 'Endpoint' does not exist.
Location: in [stage]/zones.d/director-global/service_templates.conf: 13:5-13:32
[stage]/zones.d/director-global/service_templates.conf(11): template Service "check-ping" {
[stage]/zones.d/director-global/service_templates.conf(12):     check_command = "hostalive"
[stage]/zones.d/director-global/service_templates.conf(13):     command_endpoint = host_name
[stage]/zones.d/director-global/service_templates.conf(14): }
[stage]/zones.d/director-global/service_templates.conf(15):
critical/config: 1 error
It is really weird that it is working for two of them but not the other two? I wonder if it is because those two checks are not being used since WDC-Bounce-01 is a Windows Server. Let me add a Linux server and see what happens.
Yup!
Now I am getting the same error for the SSH and HTTP service checks that I was for the winrm and ping.
critical/config: Error: Validation failed for object 'WDC-UTIL-01!check-http' of type 'Service'; Attribute 'command_endpoint': Object 'WDC-UTIL-01' of type 'Endpoint' does not exist.
Location: in [stage]/zones.d/director-global/service_templates.conf: 8:5-8:32
[stage]/zones.d/director-global/service_templates.conf(6): template Service "check-http" {
[stage]/zones.d/director-global/service_templates.conf(7):     check_command = "http"
[stage]/zones.d/director-global/service_templates.conf(8):     command_endpoint = host_name
[stage]/zones.d/director-global/service_templates.conf(9): }
[stage]/zones.d/director-global/service_templates.conf(10):
critical/config: Error: Validation failed for object 'WDC-UTIL-01!check-ssh' of type 'Service'; Attribute 'command_endpoint': Object 'WDC-UTIL-01' of type 'Endpoint' does not exist.
Location: in [stage]/zones.d/director-global/service_templates.conf: 3:5-3:32
[stage]/zones.d/director-global/service_templates.conf(1): template Service "check-ssh" {
[stage]/zones.d/director-global/service_templates.conf(2):     check_command = "ssh"
[stage]/zones.d/director-global/service_templates.conf(3):     command_endpoint = host_name
[stage]/zones.d/director-global/service_templates.conf(4): }
[stage]/zones.d/director-global/service_templates.conf(5):
critical/config: 2 errors
At first your config works fine because the service is not applied anywhere :slight_smile:
(ping, ssh and http)
So when you apply the checks to hosts, you now have the problem that your host is missing something like this :
object Endpoint "{{ inventory_hostname }}" {
  host = "{{ inventory_hostname }}"
  log_duration = 0
I would look in your host templates perhaps to see if you can configure this.
(I am thinking out loud at this point. Trying to enumerate through everything and check each little thing in an effort to debug this :slight_smile: )
Endpoints are in Director -> infrastructure
This is what mine looks like.
zones.d/AWS-NOC-02/endpoints.conf
    host = "10.10.10.20"
When I try to inspect it, I get this error. Maybe this is the core issue?
It is saying connection timed out and yet it is reachable according to the dashboard…interesting
root@AWS-NOC-02:/var/lib/icinga2/api/zones/AWS-NOC-02/director# ls
endpoints.conf  zones.conf
root@AWS-NOC-02:/var/lib/icinga2/api/zones/AWS-NOC-02/director# cat zones.conf
object Zone "WDC" {
    parent = "AWS-NOC-02"
    endpoints = [ "WDC-NOCSat-01" ]
root@AWS-NOC-02:/var/lib/icinga2/api/zones/AWS-NOC-02/director# cat endpoints.conf
Alright I just noticed something interesting. If I go to the dashboard and click on the host then it will show its check source as being the Satellite.
But if I click on the service (check-http) then it shows its check source as the master.
Thats really weird.
Let’s take a step back and look at all the configuration made at this point. I have only ever used Director and nothing else so all the conf files should be in the /var/lib/icinga2/api/ directory/zones.
root@AWS-NOC-02:/var/lib/icinga2/api/zones# ls AWS-NOC-02/director/
endpoints.conf  hosts.conf  zones.conf
root@AWS-NOC-02:/var/lib/icinga2/api/zones# cat AWS-NOC-02/director/endpoints.conf
root@AWS-NOC-02:/var/lib/icinga2/api/zones# cat AWS-NOC-02/director/hosts.conf
object Host "WDC-UTIL-01" {
    import "basic-linux"
    display_name = "WDC Linux Server"
    address = "10.10.10.30"
root@AWS-NOC-02:/var/lib/icinga2/api/zones# cat AWS-NOC-02/director/zones.conf
object Zone "WDC" {
root@AWS-NOC-02:/var/lib/icinga2/api/zones# ls WDC/director/
hosts.conf
root@AWS-NOC-02:/var/lib/icinga2/api/zones# cat WDC/director/hosts.conf
object Host "WDC112SW01" {
    import "wdc-switches"
    address = "10.10.40.80"
    address = "10.10.10.50"
root@AWS-NOC-02:/var/lib/icinga2/api/zones# ls director-global/director/
001-director-basics.conf  endpoint_templates.conf  host_templates.conf  service_templates.conf  servicesets.conf
root@AWS-NOC-02:/var/lib/icinga2/api/zones# cat director-global/director/001-director-basics.conf
const DirectorStageDir = dirname(dirname(current_filename))
globals.directorWarnedOnceForThresholds = false;
globals.directorWarnOnceForThresholds = function() {
    if (globals.directorWarnedOnceForThresholds == false) {
        globals.directorWarnedOnceForThresholds = true
        log(LogWarning, "config", "Director: flapping_threshold_high/low is not supported in this Icinga 2 version!")
const DirectorOverrideTemplate = "host var overrides (Director)"
if (! globals.contains(DirectorOverrideTemplate)) {
  const DirectorOverrideVars = "_override_servicevars"
  globals.directorWarnedOnceForServiceWithoutHost = false;
  globals.directorWarnOnceForServiceWithoutHost = function() {
    if (globals.directorWarnedOnceForServiceWithoutHost == false) {
      globals.directorWarnedOnceForServiceWithoutHost = true
      log(
        LogWarning,
        "config",
        "Director: Custom Variable Overrides will not work in this Icinga 2 version. See Director issue #1579"
  template Service DirectorOverrideTemplate {
     * Seems that host is missing when used in a service object, works fine for
     * apply rules
    if (! host) {
      var host = get_host(host_name)
    if (! host) {
      globals.directorWarnOnceForServiceWithoutHost()
    if (vars) {
      vars += host.vars[DirectorOverrideVars][name]
    } else {
      vars = host.vars[DirectorOverrideVars][name]
root@AWS-NOC-02:/var/lib/icinga2/api/zones# cat director-global/director/endpoint_templates.conf
template Endpoint "WDC Endpoint Tester" {
    port = "5665"
root@AWS-NOC-02:/var/lib/icinga2/api/zones# cat director-global/director/host_templates.conf
template Host "basic-linux" {
template Host "WDC-NOCSat-Template" {
    notes = "Dummy template for the WDC Icinga Satellite"
template Host "wdc-basic-windows" {
template Host "wdc-switches" {
root@AWS-NOC-02:/var/lib/icinga2/api/zones# cat director-global/director/service_templates.conf
root@AWS-NOC-02:/var/lib/icinga2/api/zones# cat director-global/director/servicesets.conf
 * HTTP/PING/SSH
    import "check-http"
    import "check-ssh"
    import "check-ping"
 * ping and winrm
 * ping check
 * on host wdc-basic-windows
    import "check-ping"
    assign where "wdc-basic-windows" in host.templates
Looking through this, I am not seeing any issues. Are you?
Hi @hewithaname,
So I drew it all out in a notepad because configs can be quite something to disect,
I noticed:
  • template hosts you over wrote the the command endpoint. it would ideally just be:
  • Each host does not have its own zone defined like so:
object Zone "WDC-UTIL-01" {
  endpoints = [ "WDC-UTIL-01" ]
  parent = "WDC-NOC-SAT-01"
  • all services have null defined.
Ideally they look like this ish UNLESS the service needs to run somewhere else:
template Service "generic-service" {
  max_check_attempts = 5
  check_interval = 5m
  retry_interval = 30s
  // this points to  "object Host" -> "vars.agent_endpoint = name"
  • Your satellite host alive pings it self:
Ideally:
    command_endpoint = "AW-NOC-02"
    // IF this is indeed your master?
  • your check-ping is defined twice and then applied twice for windows and linux
    import "check-ping"
and
    import "check-ping"
Not this might be a director thing but ideally you keep assigns to a minimum like this:
    import "check-ping"
    assign where host.address
This reduces the load on your master with reloading the config.
So a lot to fix still in your config but that is alright hope it helps you fix a few things
Good Evening William!
Thank you so much for looking through that. I ended up making a lot of changes to help my sanity. I ended up reinstalling the Satellite due to it just being completely out of whack. There is so much that I have learned since I first installed it and this allowed me to check each step to ensure everything was correct. This also fixed the issue of the Master and Satellite not running the same version of Icinga2.
Master = AWS-NOC-02
Satellite = WDC-NOCSat-02
This is what my Dashboard currently looks like.
  • Ensured DNS was properly configured
  • Deleted all references to the previous Satellite
  • Deleted the check-ping service template since the check_command hostalive already does a ping check
  • Ensured all firewall, acl, ufw, security groups were properly configured
  • Followed the documentation to setup the new Satellite
  • Used curl -k -s -u WDC:$PASS https://WDC-NOCSat-02.domain.corp:5665/v1 on Master to confirm that it could properly talk to the Satellite over the API.
    • <html><head><title>Icinga 2</title></head><h1>Hello from Icinga 2 (Version: r2.8.1-1)!</h1><p>You are authenticated as <b>WDC</b>. Your user has the following permissions:</p> <ul><li>*</li></ul><p>More information about API requests is available in the <a href="https://docs.icinga.com/icinga2/latest" target="_blank">documentation</a>.</p></html>
  • Fixed all the host templates so that they only have check_command = "hostalive"
  • Added max_check_attempts, check_interval, and retry_interval into my service templates
  • Fixed my Satellite host configuration so that its command_endpoint was now Master
I understand that each host should have a parent. This does make sense. I just didn’t realize that they would need their own Zone? If I have 100 hosts, then each of them will need their own Zone?
I am not seeing any way to get command_endpoint = host.vars.agent_endpoint into the configuration with Director UI. I can’t change it manually because Director will just change it back.
I feel that showing you the configuration files was very helpful so ill leave them here at the bottom again for you.
AWS-NOC-02  WDC  director-global
root@AWS-NOC-02:/var/lib/icinga2/api/zones# cd director-global/director/
root@AWS-NOC-02:/var/lib/icinga2/api/zones/director-global/director# ls
root@AWS-NOC-02:/var/lib/icinga2/api/zones/director-global/director# cat host_templates.conf
template Host "wdc-satellites" {
    command_endpoint = "AWS-NOC-02"
root@AWS-NOC-02:/var/lib/icinga2/api/zones/director-global/director# cat service_templates.conf
    max_check_attempts = "3"
    check_interval = 10s
root@AWS-NOC-02:/var/lib/icinga2/api/zones/director-global/director# cat servicesets.conf
 * HTTP/PING/SSH
 * ping and winrm
root@AWS-NOC-02:/var/lib/icinga2/api/zones/director-global/director# cd ../../WDC/director/
root@AWS-NOC-02:/var/lib/icinga2/api/zones/WDC/director# ls
host_templates.conf  hosts.conf  servicesets.conf
template Host "wdc-basic-linux" {
template Host "wdc-meraki-switches" {
    import "wdc-meraki-switches"
    display_name = "WDC112SW01"
    import "wdc-basic-linux"
 * on host wdc-basic-linux
    import "check-http"
    assign where "wdc-basic-linux" in host.templates
    zone = "WDC"
    import "check-ssh"
    zone = "WDC"
    zone = "WDC"
root@AWS-NOC-02:/var/lib/icinga2/api/zones/WDC/director# cd ../../AWS-NOC-02/director/
object Endpoint "WDC-NOCSat-02" {
    port = "5665"
    log_duration = 1d
root@AWS-NOC-02:/var/lib/icinga2/api/zones/AWS-NOC-02/director# cat hosts.conf
object Host "WDC-NOCSat-02" {
    import "wdc-satellites"
    display_name = "WDC-NOCSat-02"
object Zone "WDC" {
    endpoints = [ "WDC-NOCSat-02" ]
I hope the changes I made cleaned up my configuration. I felt like it was a complete mess and that just makes troubleshooting difficult.
Thank You!
-Adam
I will check it out tomorrow morning :slight_smile: In the mean time could you specify where you would like more help that will help me enormously, Sort of a morning puzzle to wake up the brain haha.
I see 3 problems in your first screeny Are those the problems you are trying to solve at this point in time ?
