I´m trying to automate the creation of hosts on my Icinga-director by importing from a database the FQDN/OS version and a predefined set of vars;
and then I want to merge and replace some of those vars.
When I try to merge the vars, the latest imported takes prececende,
example:
Import source 1:
ColumnName: FQDN of the host
Column vars:
cpu_load_crit: "2,1.5,1",
services: [
"SNMP",
"MySQL"
Import source 2:
Column custom_variables:
cpu_load_crit: "12,8,6",
Import source 3:
services: [
"MySQL-slave"
As per documentation, using a Sync rule (rule order 3) to
replace ${vars.cpu_load_crit} should end tiwh the nes value of cpu_load_crit: “12,8,6”,
and the Sync Rule to MERGE ${vars.services} should create the list:
"SNMP",
"MySQL",
"MySQL-slave"
Sync Rule:
Yet the merge behaviour does not work, an I get a replacement with the latest value: namely a single mysql-slave service. (the cpu_load does get replaced thought).
Preview:
Can anyone share how to actually override data on the sync rules with the merge command… if at all possible?
Th
Before you ask a question, you can check the troubleshooting documentation ºfirst, maybe you can find an answer here.
Checked automation, but this similar topics show no solution for my issue
- Director version (System - About): 1.10.2
- Icinga Web 2 version and modules (System - About): 2.11.4
- Icinga 2 version (
icinga2 --version): icinga2-2.13.6-2.el7.x86_64 - Operating System and version: CentOS 7.9.2009 : x86_64
- Webserver, PHP versions: 7.3.29
