My icinga director daemon is not starting up. its shows the error as below
Daemon has been stopped at 15:32, was running with PID 735 as icingadirector @ monitoring
Can someone help me out in this one?
Thanks in advance…!
Regards,
Shashil
Thanks in advance…!
Regards,
Shashil
Please show the output of:
which icingacli
icingacli module list
share which icingacli ?
Please find the desired result
Okay now try these
grep director /etc/passwd
su - icingadirector -s /bin/bash
icingacli director daemon run --debug --trace [stop this if it is running ]
Thanks for all your help.
Along with your commands I have also run the command
service icinga-director restart
This resolved the issue
Getting the following error -
icingadirector@monitoring:~$ icingacli director daemon run --debug --trace
Running without systemd
RuntimeException in /usr/share/icingaweb2/modules/director/library/Director/Daemon/DaemonDb.php:161 with message: DB is locked by a running daemon instance
check this
or please try reinstalling the director with all the requirements matched
https://github.com/Icinga/icingaweb2-module-director/blob/master/doc/02-Installation.md#requirements
