I want to cleanup my IDO DB because it seems that there is a little inconsistence in it. The Cube module shows a wrong number of hosts for a group, but object attributes within icinga seems to be OK.
Before searching for a possible bug in Cube I want a clean state within IDO.
Is there a recommeded way to clean the IDO without loosing historical data like notifications?
I don’t want to truncate ALL tables…
This will not work, either you have a fresh IDO DB or you leave it like it is.
Cube uses only custom variables to build “groups”, are yo usure all your hosts have the same custom variables configured to match a icinga group?
