Icinga versions:
master(Ubuntu): r2.11.4-1
satellite(Ubuntu): r2.11.4-1
agent (Windows): v2.11.4-1
My Config:
master
/etc/icinga2/zones.conf
object Endpoint "monitoring.[...]" {
host = "monitoring.[...]"
object Endpoint "monitoring-dev.[...]" {
host = "monitoring-dev.[...]"
object Endpoint "<Name>" {
log_duration = 0
object Zone "master" {
endpoints = [ "monitoring.[...]" ]
object Zone "monitoring-dev.[...]" {
endpoints = [ "monitoring-dev.[...]" ]
parent = "master"
object Zone "<Name>" {
endpoints = [ "<Name>" ]
parent = "monitoring-dev.[...]"
global = true
global = true
Satellite:
zones.conf:
port = "5665"
host = "<Name>"
log_duration = 0
object Zone "monitoring-dev[...]" {
parent = "master"
global = true
global = true
Agent:
zones.conf:
port = "5665"
parent = "master"
global = true
global = true
On master
Host
/etc/icinga2/zones.d/monitoring-dev[…]/hosts_linux.conf
object Host "<Name>" {
import "generic-host"
check_command = "hostalive"
address = "IP-Address"
vars.os = "Linux"
vars.agent_endpoint = name
vars.cluster_zone = "monitoring-dev.[...]"
vars.notification["mail"] = {
groups = [ "icingaadmins" ]
Service
/etc/icinga2/zones.d/global-templates/satellite-services.conf
apply Service "Check Linux Disk" {
import "disk-linux"
check_command = "disk"
command_endpoint = host.vars.agent_endpoint
vars.cluster_zone = host.name
assign where host.vars.cluster_zone == "monitoring-dev.[...]" && host.vars.agent_endpoint && host.vars.os == "Linux"
So the problem is now, when I stopping the Icinga2-Service on the Sattelite (or shutting down the Satellite), then the Service(-s) is/are sitll working.
The text “DISK OK - free space…” is something grayed out, but it still working and reachable. There is no Error-Status like “No connection to monitoring-dev[…] from …” on Icingaweb2.
Then I tryed it with Dependencies…
/etc/icinga2/zones.d/monitoring-dev[…]/parents.conf
apply Dependency "TEST" to Host {
parent_host_name = "monitoring-dev.[...]"
disable_checks = false
disable_notifications = true
ignore_soft_states = false
states = [ Up, Down ]
assign where host.name == "<Name>"
apply Service "ping4" {
import "generic-service"
check_command = "ping4"
assign where host.address
apply Dependency "TEST" to Service {
parent_service_name = "ping4"
states = [ OK ]
… is nothing happens, no changes.
The idea behind this, is when the Satellite is DOWN, it should be that the alert show the status for the Agent and their Services as DOWN or UNKNOWN or like that too. But it’s show’s now the status OK.
Also when the Satellite is off, then the Service ping4 from Sateliite is CRITICAL and then it must show Agent (and their Services) as Critical / Unkwnown…
You cannot see clearly, that the Agent is unreachable now (if Satellite off).
