I tried to implement it today but it doesn’t work as excepted.
I Added a NotificationCommand, template Notification and applied some services / hosts to this notifiaction.
I also specified the command_endpoint. (this option is validated by icinga, because if the host does not exist it is not working)
After running icinga2 object list I see command_endpoint is set correctly:
Object 'SomeServiceNotifiaction' of type 'Notification':
% declared in '/etc/icinga2/zones.d/global-templates/notifications.conf', lines 298:1-298:50
* __name = "HIDDEN"
* command = "jira-notification"
% = modified in '/etc/icinga2/zones.d/global-templates/templates.conf', lines 375:3-375:31
* command_endpoint = "HIDDEN ICINGAWEB2 FRONTEND NODE"
% = modified in '/etc/icinga2/zones.d/global-templates/templates.conf', lines 391:3-391:46
% = modified in '/etc/icinga2/zones.d/global-templates/notifications.conf', lines 305:3-305:46
* host_name = "HIDDEN"
% = modified in '/etc/icinga2/zones.d/global-templates/notifications.conf', lines 298:1-298:50
* interval = 7200
% = modified in '/etc/icinga2/zones.d/global-templates/notifications.conf', lines 303:3-303:15
* name = "jira_services_prod"
* package = "_etc"
* period = "24x7"
% = modified in '/etc/icinga2/zones.d/global-templates/templates.conf', lines 393:3-393:17
* service_name = "HIDDEN"
* source_location
* first_column = 1
* first_line = 298
* last_column = 50
* last_line = 298
* path = "/etc/icinga2/zones.d/global-templates/notifications.conf"
* states = [ "OK", "Warning", "Critical", "Unknown" ]
% = modified in '/etc/icinga2/zones.d/global-templates/templates.conf', lines 377:3-377:45
* templates = [ "jira_services_prod", "jira-service-notification" ]
% = modified in '/etc/icinga2/zones.d/global-templates/templates.conf', lines 374:1-374:49
* times = null
* type = "Notification"
* types = [ "Problem", "Acknowledgement", "Recovery", "Custom", "FlappingStart", "FlappingEnd" ]
% = modified in '/etc/icinga2/zones.d/global-templates/templates.conf', lines 378:3-379:40
* user_groups = null
* users = [ "jira" ]
% = modified in '/etc/icinga2/zones.d/global-templates/notifications.conf', lines 301:3-301:23
* vars
% = modified in '/etc/icinga2/zones.d/global-templates/templates.conf', lines 381:3-389:3
* jira_ack_author = "$notification.author$"
* jira_description = "$service.output$"
* jira_issuetype = "HIDDEN"
* jira_project = "HIDDEN"
* jira_state = "$service.state$"
* jira_summary = "$service.name$ on $host.name$ is $service.state$"
* jira_template = "HIDDEN"
* zone = "HIDDEN"
Object 'jira-notification' of type 'NotificationCommand':
% declared in '/etc/icinga2/zones.d/global-templates/commands.conf', lines 265:1-265:46
* __name = "jira-notification"
* arguments
% = modified in '/etc/icinga2/zones.d/global-templates/commands.conf', lines 268:5-311:5
* --ack-author
* description = "This author name will be used when acknowledging Icinga problems once a JIRA issue got created"
* value = "$jira_ack_author$"
* --command-pipe
* description = "Legacy Icinga command pipe. Should only be used on Icinga 1.x system without a correctly configured Icinga Web 2 monitoring module"
* value = "$jira_command_pipe$"
* --description
* description = "JIRA issue description"
* required = true
* value = "$jira_description$"
* --host = "$host.name$"
* --issuetype
* description = "JIRA issue type (e.g. Incident)"
* required = true
* value = "$jira_issuetype$"
* --no-acknowledge
* description = "D not acknowledge Icinga problems once a JIRA issue got created"
* value = "$jira_no_acknowledge$"
* --project
* description = "JIRA project name (e.g. IT)"
* required = true
* value = "$jira_project$"
* --service = "$service.name$"
* --state
* description = "Host/Service state (e.g. DOWN, CRITICAL)"
* value = "$jira_state$"
* --summary
* description = "JIRA issue summary"
* required = true
* value = "$jira_summary$"
* --template
* description = "Issue template name (templates.ini section). This allows to pass custom fields to JIRA"
* value = "$jira_template$"
* command = [ "/usr/bin/icingacli", "jira", "send", "problem" ]
% = modified in '/etc/icinga2/zones.d/global-templates/commands.conf', lines 267:5-267:65
* env = null
* execute
% = modified in 'methods-itl.conf', lines 23:3-23:30
* arguments = [ "notification", "user", "cr", "itype", "author", "comment", "resolvedMacros", "useResolvedMacros" ]
* deprecated = false
* name = "Internal#PluginNotification"
* side_effect_free = false
* type = "Function"
* name = "jira-notification"
* package = "_etc"
* source_location
* first_column = 1
* first_line = 265
* last_column = 46
* last_line = 265
* path = "/etc/icinga2/zones.d/global-templates/commands.conf"
* templates = [ "jira-notification", "plugin-notification-command", "plugin-notification-command" ]
% = modified in '/etc/icinga2/zones.d/global-templates/commands.conf', lines 265:1-265:46
% = modified in 'methods-itl.conf', lines 22:2-22:122
* timeout = 60
* type = "NotificationCommand"
* vars = null
* zone = "global-templates"
But I found this in the icinga log file:
[2021-11-05 12:52:22 +0100] warning/PluginNotificationTask: Notification command for object 'monitor01.agenda.de!Icinga' (PID: 25897, arguments: '/usr/bin/icingacli' 'jira' 'send' 'problem' '--ack-author' '' '--description' 'HIDDEN' '--host' 'HIDDEN' '--issuetype' 'HIDDEN' '--project' 'HIDDEN' '--service' 'Icinga' '--state' 'WARNING' '--summary' 'HIDDEN' '--template' 'HIDDEN') terminated with exit code 128, output: execvpe (/usr/bin/icingacli) failed: No such file or directory
The nagios user has all the required permissions to execute the icingacli command (on the icingaweb2 frontend node). I think the icinga master node performces this notification on it’s own node an not (as intended) on the defined command_endpoint node.
