Hey there,
every time i try running icingacli “x509 scan --job selftest” (scanning localhost:80) i´m getting an
error that my trust store is empty.
ERROR: RuntimeException in /usr/share/icingaweb2/modules/x509/library/X509/CertificateUtils.php:375 with message: Trust store is empty
But the import seams to work
icingacli x509 import --file /etc/apache2/mycert/cert.crt
Processed 1 X.509 certificate.
I´m also able to check the certificate details in icingaweb2.
Did someone encountered a similar error?
