Hello @all,
I’ve got a question about the x509 module and a master-master replication we are using in our new environment.
- Server operating system: Ubuntu 22.04.4 LTS
- PHP version: 8.2.18
- MariaDB version: 10.6.16
- IcingaDB version: 1.1.1
- Icinga Web 2 version: 2.12.1
- Icinga 2 version: 2.14.2-1
- x509 module version: 1.3.2
We use a master-master setup with virtual IP, which is controlled via HAProxy.
Both databases have corresponding entries regarding auto-increment for replication:
Server A:
auto-increment-increment = 1
auto increment offset = 2
Server B:
auto-increment-increment = 2
For all other modules, etc. it works perfectly. Only the x509 module reports errors like the following:
Error 'Duplicate entry '2004' for key 'PRIMARY'' on query. Default database: 'x509'. Query: 'INSERT INTO x509_certificate_chain (target_id,length,ctime) VALUES('29','3',UNIX_TIMESTAMP() * 1000)'
Does anyone here have an idea where there could be an error?
The x509 module is - like all other modules used - activated on both master servers.
