Hi, quick and easy question, maybe other people already had to solve this issue in the past when developing some useful addons, plugins etc. for Icinga
How can I get a normal Icinga2 and Icingaweb2 instance running on my local notebook most easily?
Icingaweb2 would be a plus but is not as needed, since I am mainly looking for API access to the master without having to emulate everything and see if it works afterwards.
Icinga
I really don’t understand this question.
Install icinga2 (and icingaweb2 if you want) on the machine just as you would
on any other machine.
There’s nothing special about installing Icinga2 on a laptop compared to
anything else.
If I’ve misunderstood and that doesn’t answer your question, please tell us
what you’re trying to do and what problem/s you run into.
Turns out it was a bit late for me yesterday. I mixed up the needed effort to install Icingaweb2 with the effort to install Icinga2, basically. Since I am running different applications using database configurations, ports etc., installing Icingaweb2 locally would not have been the best option. Anyways, I just installed Icinga2 now and am fine for now. Sorry for this rather silly question.
If you want the quickest way to install icinga2 + icingaweb2 for quick development of modules or other extensions. I would suggest to use the prepared vagrant boxes we use for demo purposes.
