Webinar: Running Monitoring and Observability at Scale - October 27
Hey everyone,
This one is a little different from our usual product webinars: we won’t showcase a new moduleor feature, but instead look at the operational side of monitoring and observability in a discussion or panel form.
Blerim Sheqa (COO at Icinga) and Kris Buytaert (Practice Lead Observability at Percona) will talk about what it actually takes to run each approach - how long it takes to get useful data, where the config lives and who owns it, and how many engineering hours go into keeping it working. And what changes between 50 hosts and 5,000.
It will be on October 27, 2026, 3 PM CET.
In this session, we’ll cover:
  • Getting data flowing: agent rollout and check definitions vs. collector deployment and instrumentation
  • Coverage limits: switches, storage appliances, VMware, UPS and PDUs, and applications nobody can recompile
  • Configuration management: where the config lives, who reviews changes, and how that holds up as you grow
  • The recurring work: check tuning and threshold drift vs. cardinality management and sampling policy
  • Requirements that only show up at scale: audit retention, budget predictability, separation of duties, data sovereignty
  • Why enterprises keep running both, and where the line usually sits
  • Interactive Q&A session
As always, you can register here :slight_smile:
