Webinar: Icinga in Your Observability Stack: Metrics via OpenTelemetry
If you’re running Icinga alongside Prometheus or Grafana, your check performance data and your metrics dashboards have probably been living in separate worlds. We think that gap is worth closing.
The OTLPMetricsWriter in Icinga 2 v2.16 is how we do it. It exports Icinga check performance data as OpenTelemetry Gauge metrics via OTLP HTTP - so your monitoring data can flow directly into Prometheus, Grafana Mimir, Datadog, VictoriaMetrics, Elasticsearch, and any other OTLP-compatible backend you’re already using.
On June 30, we’re running a hands-on session: configuring the writer, integration paths for common backends, threshold metrics, resource attributes, and HA zone behavior. Live demo and Q&A included.
June 30 | 3 PM - 4 PM CEST
Register here
