Sorry, here’s a few lines from the log - I think they capture the whole event:
[2019-02-14 10:15:25 +0000] notice/JsonRpcConnection: Received 'event::Heartbeat' message from 'zenoss.hpc.imperial.ac.uk'
[2019-02-14 10:15:27 +0000] information/ApiListener: New client connection from [192.168.96.134]:51328 (no client certificate)
[2019-02-14 10:15:27 +0000] notice/ApiListener: New HTTP client
[2019-02-14 10:15:27 +0000] debug/HttpRequest: line: POST /v1/actions/process-check-result?service=/cx1-106-1-1.cx1.hpc.ic.ac.uk!cx1-mom-check HTTP/1.1, tokens: 3
[2019-02-14 10:15:27 +0000] notice/WorkQueue: Spawning WorkQueue threads for 'HttpServerConnection'
[2019-02-14 10:15:27 +0000] information/HttpServerConnection: Request: POST /v1/actions/process-check-result?service=/cx1-106-1-1.cx1.hpc.ic.ac.uk%21cx1-mom-check (from [192.168.96.134]:51328, user: client-pki-ticket-cx1-admin)
[2019-02-14 10:15:27 +0000] warning/TlsStream: TLS stream was disconnected.
[2019-02-14 10:15:27 +0000] debug/HttpServerConnection: Http client disconnected
[2019-02-14 10:15:27 +0000] notice/WorkQueue: Stopped WorkQueue threads for 'HttpServerConnection'
[2019-02-14 10:15:29 +0000] notice/JsonRpcConnection: Received 'log::SetLogPosition' message from 'zenoss.hpc.imperial.ac.uk'
[2019-02-14 10:15:30 +0000] information/WorkQueue: #4 (ApiListener, RelayQueue) items: 0, rate: 0.133333/s (8/min 8/5min 8/15min);
[2019-02-14 10:15:30 +0000] information/WorkQueue: #5 (ApiListener, SyncQueue) items: 0, rate: 0.0166667/s (1/min 1/5min 1/15min);
[2019-02-14 10:15:30 +0000] notice/CheckerComponent: Pending checkables: 0; Idle checkables: 15; Checks/s: 0
[2019-02-14 10:15:30 +0000] notice/ApiListener: Setting log position for identity 'zenoss.hpc.imperial.ac.uk': 2019/02/13 16:47:02
[2019-02-14 10:15:30 +0000] information/WorkQueue: #8 (JsonRpcConnection, #0) items: 0, rate: 0.1/s (6/min 6/5min 6/15min);
[2019-02-14 10:15:30 +0000] information/WorkQueue: #10 (JsonRpcConnection, #2) items: 0, rate: 0/s (0/min 0/5min 0/15min);
Icinga version:
[root@cx1-admin home]# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.8.1-1)
Copyright (c) 2012-2017 Icinga Development Team (https://www.icinga.com/)
Application information:
Installation root: /usr
Sysconf directory: /etc
Run directory: /run
Local state directory: /var
System information:
Platform: CentOS Linux
Platform version: 7 (Core)
Kernel: Linux
Kernel version: 3.10.0-693.11.6.el7.x86_64
Architecture: x86_64
Build information:
Compiler: GNU 4.8.5
Build host: unknown
The curl request:
bash-4.2$ curl -k -s -u cx1adminroot:fgadgsdfhetyd 'https://admin.cx1.hpc.imperial.ac.uk:5665/v1/objects/services/cx1-106-1-1.cx1.hpc.ic.ac.uk!cx1-mom-check' | python -m json.tool
"error": 404.0,
"status": "No objects found."
And the update:
def report(self,status,alertstr):
# authentication
# https://stackoverflow.com/questions/26745462/basic-authentication-not-working-with-requests-library
headers={
'Accept':'application/json'
data={
'exit_status':status,
'plugin_output':alertstr,
'check_command':[self.cmd]
#self.logger.info('%s result: %s'%(self.cmd,alertstr))
try:
print "service.report: %s, %s/%s" % (self.murl,self.musernm,self.mpasswd)
r=requests.post(
self.murl,
headers=headers,
auth=(self.musernm,self.mpasswd),
data=json.dumps(data)
except Exception,arg:
print 'POST to %s failed\n%s' % (self.url,arg)
else:
print 'service.report: %s' % r
The python code used to work in the past, when the services used to be defined in /etc/icinga2/zones.d/cx1-zone/services.conf, so I feel it ought to work still.
