Hello
When using the following command to check a datastore:
icingacli vspheredb check datastore --name NFS_TEMPLATE
I’m getting the following output:
[UNKNOWN] More than one object found for given filter
The reason are multiple datastores having the same name.
So I want to use the uuid to filter the datastore, but how do I query a usable uuid out of the vspheredb objects database?
Using
SELECT object_name,object_type,uuid FROM object where object_type='Datastore';
I’m getting back something like
bytearray(b'\x16\xe5K\x90\x17B[a\xa9x\n(L\xcf;\xab')
for the uuid, which is not working for the check.
Currently I’m not using Director, so I’m using a python script to create the hosts for Icinga. The Script is using pythons mysql.connector to query the vspheredb.
My versions:
icinga2: r2.13.5-1
icingaweb2: 2.11.1
vspheredb: 1.5.0
icingadb: 1.0.1
mariadb: 10.3.35
