Today i installed the vspheredb Module. The Module is enabled, dependencies are solved, vspheredb is successfully connected to our vCenter 7.x. and is receiving a lot of data.
but…i don’t see any graphics, pictures, graphs and so on.
used versions:
# icingacli module list
MODULE VERSION STATE DESCRIPTION
businessprocess 2.4.0 enabled A Business Process viewer and modeler
doc 2.11.1 enabled Documentation module
graphite 1.2.1 enabled Icinga Graphite module
incubator 0.18.0 enabled Incubator provides bleeding-edge libraries
ipl v0.5.0 enabled The Icinga PHP library
monitoring 2.11.1 enabled Icinga monitoring module
vspheredb 1.4.0 enabled VMware vSphere DB
# yum list installed | grep ...
icingaweb2.noarch 2.11.1-1.el7.icinga
rh-php73-php-common.x86_64 7.3.33-1.el7
rh-php73-php-soap.x86_64 7.3.33-1.el7
rh-php73-php-cli.x86_64 7.3.33-1.el7 ##php-pcntl
rh-php73-php-process.x86_64 7.3.33-1.el7 ##php-posix
Screenshots:
Any idea what’s wrong!?!?
