Hello Community,
recently we moved our 2 vCenters into a new one and I tried to delete the connections and the entry’s.
On the “Virtualization (VMware) → Configuration” the old entry’s are deleted, but on the Main page of “Virtualization (VMware)” it stills exist
Also inside the “Director → Import source” I can still select the old ones. Is there a way to cleanup the old connections?`
A simple:
delete from vcenter where name="vCenter-Name";
causes an error:
ERROR 1451 (23000): Cannot delete or update a parent row: a foreign key constraint fails (`vspheredb`.`monitoring_connection`, CONSTRAINT `monitoring_vcenter` FOREIGN KEY (`vc
enter_uuid`) REFERENCES `vcenter` (`instance_uuid`) ON UPDATE CASCADE)
Thanks in advance
- Director version (System - About):1.9.1
- Icinga Web 2 version and modules (System - About): 2.9.5
- Icinga 2 version (
icinga2 --version
): 2.13.2-1 - vspheredb:1.4.0
- Operating System and version: RockyLinux 8
- Webserver, PHP versions:
- Apache 2.4.37-41
- PHP 7.4.19
