I have an icinga platform constitute like this :
- 1 web node on site A
- 1 db node on site A
- 2 master node (one an each of our 2 site)
I want to use the vsphere integration for monitore my vcenter.
I installed it successfully and I have now the “virtualization” tab in my web ui but I now want to create a check for my entire vcenter.
I saw the command like
icingacli vspheredb check health
witch seems to do the job but it not working from my master node because there is not icingaweb installed on it.
My question is :
- Can I use it or it’s impossible with my configuration
- If the first answer is yes, then how should I do it ?
