Good morning,
I have an issue with the icingaweb2 VMware-Module.
# systemctl status icinga-vspheredb.service
● icinga-vspheredb.service - Icinga vSphereDB Daemon
Loaded: loaded (/etc/systemd/system/icinga-vspheredb.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2020-03-12 07:28:23 CET; 26min ago
Docs: https://icinga.com/docs/icinga-vsphere/latest/
Main PID: 2156724 (icingacli)
Status: "DB has been cleaned up"
Tasks: 1 (limit: 9490)
Memory: 13.3M
CGroup: /system.slice/icinga-vspheredb.service
└─2156724 Icinga::vSphereDB::main: 3 active runners
Mar 12 07:28:23 98lipmoni3 systemd[1]: Started Icinga vSphereDB Daemon.
Mar 12 07:32:42 98lipmoni3 icingacli[2156724]: Got invalid NetString data:
Mar 12 07:32:42 98lipmoni3 icingacli[2156724]: Fatal error: Uncaught Error: Class 'SoapVar' not found in /usr/share/icingaweb2/mod>
Mar 12 07:32:42 98lipmoni3 icingacli[2156724]: Server for vCenterID=2 failed, will try again in 30 seconds
Mar 12 07:32:42 98lipmoni3 icingacli[2156724]: Server for vCenterID=4 failed, will try again in 30 seconds
Mar 12 07:32:42 98lipmoni3 icingacli[2156724]: Server for vCenterID=6 failed, will try again in 30 seconds
# icingacli vspheredb daemon run --trace --debug
Fatal error: Uncaught Error: Class 'SoapVar' not found in /usr/share/icingaweb2/modules/vspheredb/l[..] truncated 1120 bytes [..] a\Module\Vspheredb in /usr/share/icingaweb2/modules/vspheredb/library/Vspheredb/Api.php on line 410
Pid 2158637 stopped
Pid 2158638 stopped
Pid 2158639 stopped
SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry '\x8D\xA3\xF8\xE6I\x00s\xFE\xBA\x18K#\xCE\x92=\x1C' for key 'PRIMARY', query was: INSERT INTO vspheredb_daemon (instance_uuid, ts_last_refresh, process_info, pid, fqdn, username, php_version) VALUES (?, ?, ?, ?, ?, ?, ?)
Database connection has been closed
I changed the WatchdogSec=10 to WatchdogSec=360 in /etc/systemd/system/icinga-vspheredb.service - no success
Icingaweb2-Version 2.7.3
|Dependencies|
ipl : >=0.3.0
incubator : >=0.5.0
reactbundle : >=0.7.0|
|Permissions|vspheredb/admin : Allow to configure vCenter connections|
