Hi all,
after updateting to icingaweb 2.8 i found some glitches in the web UI.
The area marked red in the screenshot below, was not available in version 2.7. I assume that this is not an intentional behavior, because the search string is not preserved when you click on templates, for example
In addition, the area marked in red is new in the mobile view. However, if you use a link from the area, you will not end up with the intended object. I therefore assume that this is also a issue.
I am using PHP 7.3 on a Centos 7
Anyone here havevong the same issues?
Kind Regards
