Hi all,
I am looking for a good check to monitor the Vcenter and all servers that are in the VCenter. Unfortunately, the VSphere module currently has too few functions. I would like to be able to detect a full memory via this check, for example. Can you recommend a good check?
I hope CPU and RAM rules get added soon.
This way I could remove some checks form the agent and save some CO2.
One could write a check to query the database but for this the ID of the Host / VM would need to be accessible to the director import.
I decided to use the Vcenter check check_vmware_esx. GitHub - BaldMansMojo/check_vmware_esx: chech_vmware_esx Fork of check_vmware_api.pl it is a fork of the old check check_vmware_api
