I just wondered, what the community thinks about refactoring “quick actions”, “Actions”, “Feature Commands” combined into an “Actions” dropdown or a dedicated “Actions” tab?
Negatives:
Quick actions would be obscured, if moved to an “Actions” dropdown or would be obscured and require an additional click, if moved to an “Actions” tab.
Positives:
The div with class “controls” would look cleaner or possibility to make “object-meta-info-control collapsible-control” obsolete.
Balancing the “tabs primary-nav nav” div, that looks a bit anemic, with the service tab’s “content” div, that looks chaotic and overladen.
No more searching and scrolling for “Actions” and “Feature Commands”.
PS: I Also just noticed the duplication of functionality and danger (accidentally exposed passwords!) of “Action” inspect and the Source Tab in the IcingaDB.
