Hello all,
First of all, happy new year
is there a way to restrict the view of a user in the map module?
The user itself can only see some hosts in the host overview, but in the map, all hosts are visible.
Many thanks in advance.
log1c
January 3, 2023, 2:00pm
2
Doesn’t seem to support ACLs.
Maybe open a Feature request on github.
You could try adding filters to the URL and then add that view to the dashboard:
# Exploring the map
Once you enable the *Host Map* module, it will pop up in your menu in the ``Maps`` section.
When you click on it, it will show you a map:
## Basic usage
Every host is represented by a colored marker, which indicates the overall host state.
Markers are grouped into clusters, depending on their location and the zoom level. Every cluster marker has a label with the number of clustered markers.
By clicking on the icon, the cluster expands and the underlying host markers will be visible:
To show more details about a host click on the host marker. If you want to show the host in the detail view of the `monitoring module` just click on the eye icon.
This file has been truncated. show original
