Use same check with different values on same host
I have a host with different kinds of drives on which I want to apply a smart check:
plugin file: /usr/lib/nagios/plugins/check_smart.pl
Command definition:
object CheckCommand "smart_attributes" {
        import "plugin-check-command"
        command = [ PluginDir + "/check_smart.pl" ]
        arguments = {
                "-d" = {
                        value = "$smart_devices$"
                        description = "A physical block device to be SMART monitored"
                "-g" = {
                        value = "$smart_global$"
                        description = "A glob expression of physical devices to be monitored"
                "-i" = {
                        required = true
                        value = "$smart_interface$"
                        description = "Drive's interface type"
                "-r" = {
                        value = "$smart_raw$"
                        description = "List (comma separated, without spaces!) of SMART attributes to check for their raw values"
                "-b" = {
                        value = "$smart_attributes_bad$"
                        description = "Threshold value (integer) when to warn for N bad entries"
                "-w" = {
                        value = "$smart_warn$"
                        description = "Comma separated list of thresholds for ATA drives"
                "-e" = {
                        value = "$smart_exclude$"
                        description = "List of (comma separated) SMART attributes which should be excluded (=ignored) from checks."
                "-E" = {
                        value = "$smart_exclude_all$"
                        description = " List of (comma separated) SMART attributes which should be excluded (=ignored) completely, for both checks and performance data."
                "-s" = {
                        value = "$smart_selftest$"
                        description = "Additionally check SMART's selftest log for errors."
                "-l" = {
                        value = "$smart_ssd_lifetime$"
                        description = "Additionally check attribute 'Percent_Lifetime_Remain' which is available on some SSD drives."
Service Definition:
apply Service "check_smart_sata" {
        import "generic-service"
        check_command = "smart_attributes"
        assign where host.vars.smart_sata
        host.vars.smart_global = "/dev/sd[a-z]"
        host.vars.smart_interface = "ata"
apply Service "check_smart_nvme" {
        assign where host.vars.smart_nvme
        host.vars.smart_global = "/dev/nvme[0-9]"
        host.vars.smart_interface = "nvme"
apply Service "check_smart_scsi" {
        assign where host.vars.smart_scsi
        host.vars.smart_global = "/dev/da[0-9]"
        host.vars.smart_interface = "scsi"
apply Service "check_smart_raid_ctrl" {
        assign where host.vars.smart_cciss
        host.vars.smart_interface = "cciss,0"
apply Service "check_smart_dom" {
        assign where host.vars.smart_dom
        host.vars.smart_global = "/dev/ada[0-9]"
        host.vars.smart_interface = "auto"
object Host "<hostname>" {
import "generic-host-bm-bsd"
address = "10.X.X.X"
vars.smart_dom = true
vars.smart_nvme = true
vars.smart_scsi = true
The three smart checks are all executed with the value for the scsi drives da[x], thus also the nvme check and the dom check are looking for a device named da[x]. Seems that last match wins. If I disable the other checks and each check is applied alone, they work stand-alone as intended (e.g. checking for nvd0).
(Somehow similar to this problem, but thew solution does not fit for me)
Right now I’m a little stuck - so any idea to make it work?
Thank you very much!
Icinga Version Info:
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.13.7-1)
Copyright (c) 2012-2023 Icinga GmbH (https://icinga.com/)
System information:
  Platform: Debian GNU/Linux
  Platform version: 10 (buster)
  Kernel: Linux
  Kernel version: 4.19.0-23-amd64
  Architecture: x86_64
Build information:
  Compiler: GNU 8.3.0
  OpenSSL version: OpenSSL 1.1.1n  15 Mar 2022
You should use vars.smart_global instead of host.vars.smart_global etc.
You can use an “apply-for” rule:
apply Service "smart: " for ( smart => config in host.vars.smart ) {
  vars += config  # important!
vars.smart["scsi"] = {
vars.smart["nvme"] = {
Details about this can be found here: Monitoring Basics - Icinga 2
But this currently only works with the Icinga DSL, not in the director (as far as I know)
Thank you very much, I’m gonna try it out.
I’m not using Director, but the cli / text config files.
Edit: thank you very much, that made it work! :grinning: :+1:
