Hi community,
I really like the new icingadb module in icingaweb. How can I use it as default for my search results? I don’t want to click on “Preview this in Icinga DB” every time. It doesn’t seem to keep this setting.
Thanks and kind regards Markus
Disable the monitoring module
Thanks that’s quite easy
Can I safely remove the old ido database after disabling the monitoring module and disabling the ido feature in Icinga?
that depends, if you use idoreports, you shouldn’t remove ido module.
