Hi all,
I try to monitor an Oracle database with “oracle_health” and various checks reading from a dictionary. This works fine for those checks which do not need an additional argument e.g. tnsping. For checks which need additional arguments like “tablespace_usage” one has to define additional variables. I did it in the host object but the check use the last tablespace name only. What’s wrong?
The service is like:
apply Service "ORACLE: " for (mode => config in host.vars.oracle_health) {
import "generic-service"
check_command = "oracle_health"
vars.oracle_home = "/usr/lib/oracle/12.1/client64"
vars.oracle_ld_library_path = "/usr/lib/oracle/12.1/client64"
vars.oracle_tns_admin = "/usr/lib/oracle/12.1/client64/network/admin"
vars.oracle_health_mode = mode
vars += config
vars.oracle_health_connect = "$host.name$"
vars.oracle_health_username = "<USER>"
vars.oracle_health_password = "<PASSWORD>"
#assign where match ("slesora-dev.*", host.name)
assign where match ("slesora*", host.name)
The variables are defined in the host object:
vars.oracle_health["connected-users"] = {}
vars.oracle_health["session-usage"] = {}
vars.oracle_health["process-usage"] = {}
vars.oracle_health["connection-time"] = {}
vars.oracle_health["flash-recovery-area-usage"] = {}
vars.oracle_health["invalid-objects"] = {}
vars.oracle_health["tnsping"] = {}
vars.oracle_health["rman-backup-problems"] = {}
vars.oracle_health["tablespace-usage"] = {
oracle_health_name = [ "SYSTEM", "USERS" ]
The object looks like:
root@ucsnetmon2:/etc/icinga2/conf.d/local.d# icinga2 object list --name "ORACLE: tablespace-usage"
Object 'slesora.ltbbg1.lvnbb.de!ORACLE: tablespace-usage' of type 'Service':
% declared in '/etc/icinga2/conf.d/local.d/elvis2.conf', lines 290:1-290:72
* __name = "slesora.ltbbg1.lvnbb.de!ORACLE: tablespace-usage"
* action_url = ""
* check_command = "oracle_health"
% = modified in '/etc/icinga2/conf.d/local.d/elvis2.conf', lines 292:3-292:33
* check_interval = 600
% = modified in '/etc/icinga2/conf.d/templates.conf', lines 28:3-28:22
* check_period = ""
* check_timeout = null
* command_endpoint = ""
* display_name = "ORACLE: tablespace-usage"
* enable_active_checks = true
* enable_event_handler = true
* enable_flapping = false
* enable_notifications = true
* enable_passive_checks = true
* enable_perfdata = true
* event_command = ""
* flapping_threshold = 0
* flapping_threshold_high = 30
* flapping_threshold_low = 25
* groups = [ ]
* host_name = "slesora.ltbbg1.lvnbb.de"
% = modified in '/etc/icinga2/conf.d/local.d/elvis2.conf', lines 290:1-290:72
* icon_image = ""
* icon_image_alt = ""
* max_check_attempts = 5
% = modified in '/etc/icinga2/conf.d/templates.conf', lines 27:3-27:24
* name = "ORACLE: tablespace-usage"
* notes = ""
* notes_url = ""
* package = "_etc"
* retry_interval = 60
% = modified in '/etc/icinga2/conf.d/templates.conf', lines 29:3-29:21
* source_location
* first_column = 1
* first_line = 290
* last_column = 72
* last_line = 290
* path = "/etc/icinga2/conf.d/local.d/elvis2.conf"
* templates = [ "ORACLE: tablespace-usage", "generic-service" ]
% = modified in '/etc/icinga2/conf.d/templates.conf', lines 26:1-26:34
* type = "Service"
* vars
% = modified in '/etc/icinga2/conf.d/local.d/elvis2.conf', lines 300:3-300:16
* oracle_health_connect = "$host.name$"
% = modified in '/etc/icinga2/conf.d/local.d/elvis2.conf', lines 302:3-302:44
* oracle_health_mode = "tablespace-usage"
% = modified in '/etc/icinga2/conf.d/local.d/elvis2.conf', lines 298:3-298:32
* oracle_health_name = [ "SYSTEM", "USERS" ]
* oracle_health_password = "<PASSWORD>"
% = modified in '/etc/icinga2/conf.d/local.d/elvis2.conf', lines 304:3-304:46
* oracle_health_username = "<USER>"
% = modified in '/etc/icinga2/conf.d/local.d/elvis2.conf', lines 303:3-303:40
* oracle_home = "/usr/lib/oracle/12.1/client64"
% = modified in '/etc/icinga2/conf.d/local.d/elvis2.conf', lines 294:3-294:52
* oracle_ld_library_path = "/usr/lib/oracle/12.1/client64"
% = modified in '/etc/icinga2/conf.d/local.d/elvis2.conf', lines 295:3-295:63
* oracle_tns_admin = "/usr/lib/oracle/12.1/client64/network/admin"
% = modified in '/etc/icinga2/conf.d/local.d/elvis2.conf', lines 296:3-296:71
* volatile = false
* zone = ""
Regards and Thanks
Stephan
