I have to upgrade the entire system to assure compliance between the actual master and a new master I created. Unluckly I read that in the newest versions some big changes happened such as the change of the DB from IDO Db to IcingaDB so I really need to upgrade my system
Can someone explain me how to upgrade everything without loosing data?
I saw there are not baskets for hosts, services and commands but only for groups so I think that the best practice is not to save the backup of the db, erase icinga and reinstall the newest version
I will need also to embed grafana graphs in a second time
Yes, you can move the IDO but beware schema updates.
I think the current version of the Icingaweb2 Grafana widget requires IcingaDB so until you switched to IcingaDB you need the older release. I have it working with IDO and the current Icingaweb2.
