Icinga Web 2 version
icingaweb2-2.10.1-1.el7 -
Used modules and their versions (System - About)
Incubator 0.17.0
IPL v0.5.0
Reactbundle 0.9.0
Director v1.9.1 -
Web browser used
Google Chrome -
Icinga 2 version used (
icinga2 --version
Icinga 2 r2.13.3-1 -
PHP version used (
php --version
PHP 8.0.20 on System
PHP 7.3 in Icingaweb2 -
Server operating system and version
CentOS 7 - centos-release-7-9.2009.1.el7.centos.x86_64
Hello everyone,
I was told I should update the PHP Version of our icingaweb2 from PHP 7.3 to PHP 8.0. I already updated the PHP Version on our Serversystem but I did not find any way to update the PHP Version in Icingaweb2 so it will use PHP 8.0 instead of the 7.3 Version.
As I installed Icinga lately, I followed the installationorder of Icinga (icingaweb2/doc at master · Icinga/icingaweb2 · GitHub) but it required rh-php73 as dependency, so I installed it with PHP 7.3, which was obviously not wanted.
I know this might be a dumb question, but I didn’t find any hint to update just the PHP Version, only how to update the icingaweb2 version, which is up to date, beacause it’s a 3 days old installation
Best of regards:
Daniel
Edit:
In the meantime, I had a look into yum list | grep fpm:
rh-php73-php-fpm.x86_64 7.3.29-1.el7 @centos-sclo-rh
fpm2.x86_64 0.79-12.el7 epel
php-fpm.x86_64 8.0.20-1.el7.remi remi-php80
php54-php-fpm.x86_64 5.4.45-19.el7.remi remi-safe
php55-php-fpm.x86_64 5.5.38-13.el7.remi remi-safe
php56-php-fpm.x86_64 5.6.40-33.el7.remi remi-safe
php70-php-fpm.x86_64 7.0.33-33.el7.remi remi-safe
php71-php-fpm.x86_64 7.1.33-20.el7.remi remi-safe
php72-php-fpm.x86_64 7.2.34-11.el7.remi remi-safe
php73-php-fpm.x86_64 7.3.33-3.el7.remi remi-safe
php74-php-fpm.x86_64 7.4.30-1.el7.remi remi-safe
php80-php-fpm.x86_64 8.0.20-1.el7.remi remi-safe
php81-php-fpm.x86_64 8.1.7-1.el7.remi remi-safe
php82-php-fpm.x86_64 8.2.0~alpha2-7.el7.remi
rh-php70-php-fpm.x86_64 7.0.27-2.el7 centos-sclo-rh
rh-php71-php-fpm.x86_64 7.1.30-2.el7 centos-sclo-rh
rh-php72-php-fpm.x86_64 7.2.24-1.el7 centos-sclo-rh
